Rear wheels -19"x9.5 265/30zr-19- possible?
Old Nov 17, 2006 | 11:56 AM
sh500's Avatar
Default Rear wheels -19"x9.5 265/30zr-19- possible?
Hi all,
I was just wondering if the wheels as per dimensions on subject line would be suited to the rear of my 2000 A6? I would think about lowering the car too, so just wanted to know if the arches would clear when car is fully laden.
Many thanks.
Old Dec 10, 2006 | 10:42 AM
sh500's Avatar
Default RE: Rear wheels -19"x9.5 265/30zr-19- possible?
Any info on this guys?
Thanks
Old Dec 10, 2006 | 11:54 AM
Kevin's Avatar
Try Audiworld.com. This site has limited activity.
Old Dec 11, 2006 | 07:03 PM
fly5150's Avatar
Yes they will fit. I had 275-30-20 on the back of mine and they looked great
Old Feb 27, 2007 | 10:57 PM
scotto467's Avatar
Before you do this be aware that all four wheel sizes need to match on a quattro. If they don't you will likely damage a $9,000.00 transmission.
Old Mar 2, 2007 | 09:26 AM
sh500's Avatar
I ended up going for the RS6 ones in the end.
Fly, I think it's because you've got the 4.2 with OEM 'flared' arches that you can manage such a wide tyre size (?) I've got a 2000 2.4 SE...
Old Mar 2, 2007 | 11:22 AM
joshpsu's Avatar
ORIGINAL: scotto467
understood on the sizes, but I have 18" in front and back, but the back one is wider. Is it ok to have wider rims in the back, but still the same diameter as the front?
Old Mar 2, 2007 | 12:25 PM
votblindub's Avatar
i dont think 9.5s will fit in there, man. 19x8.5 should go in fine, but 9 wide is problematic, from what ive read.
Old Mar 2, 2007 | 12:30 PM
votblindub's Avatar
ORIGINAL: joshpsu
ORIGINAL: scotto467
Old Mar 2, 2007 | 12:48 PM
joshpsu's Avatar
but see thats what I dont fully understand. I see if you have 18" in the front and 19" in the back that it can mess up the transmission, but if the wheels are the same diameter (18" in my case) but the back wheels are a bit wider then the front, will this also cause a problem (assume they were put on and aligned correctly)
