rear windows
Old Apr 27, 2007 | 05:40 PM
aud99's Avatar
Default rear windows
the rear windows are going up and down using the driver side control but it wont work with the rear control wat could be the problem thanx
Old Apr 28, 2007 | 07:44 AM
mustang196718's Avatar
Default RE: rear windows
not trying to be a smart a$$, but is the little rear window lock button lit up on the drivers side window switch panel? if that's depressed and lit, that would cause the rear windows to not operate with the switches back there.
Old Apr 29, 2007 | 05:58 AM
aud99's Avatar
that was the 1st thing i looked could it be a fuse blown?
Old Apr 29, 2007 | 03:37 PM
auditech79's Avatar
Try this it takes two people, have one person hold down the rear window lock out switch from the driver's door and have another person operate the switch that isn't working, if the windows go down you have a bad master window switch, happens all the time.
Old May 6, 2007 | 01:31 AM
Cmoney's Avatar
I have a 2000 2.7. I had the same problem. It was a bad master switch. Like auditech said, I could hold the button down and the back window switches would work. I was getting some warranty work down so I just added that to it. I think audi charged about $90 for the switch. Some guys say that they were able to take the switch out and clean the contacts off and it worked fine. Good luck.
99AudiSport
Jan 27, 2013 03:32 PM
quattro/2.8
Sep 23, 2007 11:48 PM
16w/A4
Jun 30, 2006 05:40 AM
haveaseat
Mar 11, 2006 11:21 PM
99silverA6
Feb 8, 2006 01:33 AM
