recoding the tranny to sports mode
Hi, after reading tons on recoding the tranny to sports mode, and having it able to hold 1st gear in tip mode using code 00032, or 00030 in other cars, I bought the vag-com cable from ebay. My stock code was 00000, and I tried to recode it, but I wasn't able to recode it to anything except to 00010. None of the other #s worked at all. I tried both 00030, 00020, 00032, 01032, 01030, but It won't take any codes except the 00010 or 00000. I'm wondering if any one else had this issue. Apparently it's not an issue of correct codes, does any one know how to make this work? I'm driving a 2000 a6 2.8 quattro by the way.
Thanks
Thanks
All right I just read something on the forums that says I need to go into adaptation and change the last 2 #s to 32. What I've been doing is going to recode then changing the soft code, but not adaptation. Which of these is correct? I'm using vag-com of course.
