How do I use Sports mode on auto transmission?
Old Mar 30, 2008 | 11:30 PM
Project's Avatar
Default How do I use Sports mode on auto transmission?
How do I use this? Can I just switch over whenever? I switched it like 3 times from Drive while on the freeway, I wanna make sure I didn't f it up.
Old Mar 30, 2008 | 11:53 PM
espeed's Avatar
Default RE: How do I use Sports mode on auto transmission?
You just put it into S whenever you want to it won't damage anything. On the highway I don't believe it makes any difference if its in drive or S mode. But on regular street grounds it does keep the rpms higher then in D. Hope it helped
Old Mar 31, 2008 | 12:00 AM
Project's Avatar
Thanks
Does it use more gas up?
Does it help with suspension/turning?
Is keeping the RPMs higher a good thing?
Old Mar 31, 2008 | 12:59 AM
joetm's Avatar
bump
Old Mar 31, 2008 | 01:01 AM
WeezyTT's Avatar
Yes
Not sure but i don't think so
Depends if you want better throttle response, otherwise you're wasting gas for no reason
Old Mar 31, 2008 | 01:59 AM
Project's Avatar
Please explain what increased throttle response will do?
Old Mar 31, 2008 | 09:37 AM
joetm's Avatar
well look at it this way in if your in D and you come out of a corner youll most likely be braking into/throughout the corner so your trans will be in 5th gear when u go to give it gas it will have to think to upshift to second or third gear for you to get proper acceleration ... now S will hold a gear till a little over 3000rpms so if your going into the corner Smode will keep your trans in a lower gear bc it is programed to keep the trans around 3000rpm and when your coming out of the corner you will still be in 3rd gear and when u step on it ull instandly swing out of the corner ... D is way more gas efficient i have found bc i drove in S for about a week and it ate all my gas ... i too was wondering if it was bad to keep the rpms up that high but i guess not(didnt want to start burning oil)
but increased throttle response doesnt really mean anything unless your racing or fooling around with another car or just having fun
Old Mar 31, 2008 | 08:28 PM
Wayne.L's Avatar
best way to experience the S is to put the car into S and slam on the throttle~ such a sensation... not on highway thro..wont make a difference, but if you are on roads with lots of throttle then brake then throttle again, you can realy tell the difference from D~~ but BE SAFE!
Old Sep 29, 2018 | 01:55 PM
Sam Wilson's Avatar
Default good mpg in sport mode
so today just driving around pretty empty streets at 35mph in sport mode I realised that my mpg was great as it was on cruise control but driving in a low gear till I pressed accelerator is it bad for the engine to be in such a high gear
msodrew
Oct 23, 2008 12:52 PM
incrementalg
Jul 7, 2008 09:30 AM
BOOSTME
Mar 10, 2008 06:27 PM
fyrwlkr
May 17, 2007 03:55 PM
JETSPEED333
Feb 16, 2007 09:29 PM
