Removing Trunk Lid Panel
Old Dec 29, 2008 | 12:41 AM
mattmoo's Avatar
Default Removing Trunk Lid Panel
I have a 2004 A6 2.7t and whenever I open or close my trunk lid, something rattles around between the lining (or panel) and the metal of the lid. This is the part behind the orange reflector triangle. I can't figure out how to remove the panel...I would also like to install some Dynamat behind it too because I just had subwoofers installed. If anyone has any insight on how to remove the liner, it would be appreciated.
Thanks
Old Dec 29, 2008 | 01:38 AM
chefro's Avatar
I bet is held in place by plastic clips, but the guys with the Audi "bible" (repair manual) should be able to tell you exactly what you have to do.
Old Dec 29, 2008 | 02:29 AM
2001A6's Avatar
Ok, its easy. I had the same problem, turns out some of the nuts that hold the lp surround on fell off! Its much quieter now, and sounds solid! Mostly held on by the the little metal clips that slide into slits in the trunk I believe. Il look tomorrow, I forgot. I know theres two screws it the plastic grab handle, maybe something behind the triangle as well. Really, its pretty easy. I didnt look up any instructions, just went out and carefully started pulling it down.
Old Dec 29, 2008 | 02:21 PM
mattmoo's Avatar
Thanks, I took out the screws on the reflector holder and then I just pulled and the metal clips came out. The plastic piece that was rattling around fell out and everything's good now. The trunk shakes so much with the subs...I guess I'll have to soundproof it :/
hannesr
Dec 8, 2014 08:15 PM
Josiah31
Aug 15, 2011 09:30 PM
rollyfoster
Apr 16, 2009 04:32 PM
RadRup
Aug 11, 2006 11:38 PM
Murdy
May 12, 2006 12:28 PM
