Replace Radio on 1995 A6
Old Dec 26, 2009 | 02:32 PM
mark0101's Avatar
Default Replace Radio on 1995 A6
Hello,
My stock factory Bose radio deck is broken so I'm trying to replace it with a new one with an AUX input and just bypass the 6-CD changer (which is also broken).
Does the stock radio have a built-in power-amplifier or is it seperate? Will I need to cut all the wires and attach a new wiring harness, or can I get some kind of harness adapter?
Any suggestions on a deck which will be compatible?
I am a complete Noob. So all tips are appreciated!
Gamma CC
Audi part # 4A0 035 093
Audi part # 4A0 035 192
Alpine part # 4D0 035 111 6-disc CD Changer
Old Dec 26, 2009 | 03:37 PM
maxim_s45's Avatar
Hi! In my Audi A6 94 - the radio (Gamma CC by Panasonic) was working with an external amplifier located in a trunk between speakers.
Newer radios typically have built-in amp and therefore you have to by pass the amp! Also Gamma is a different size than 1 din standard, so you might look for plastic stubs to fit the new radio.
Old Dec 27, 2009 | 02:03 PM
mark0101's Avatar
thanks Maxim.
Anyone know about the wiring? Are they standard color coded or do I need a wiring diagram?
Old Dec 27, 2009 | 09:23 PM
maxim_s45's Avatar
http://elsegra.com/Car%20pinouts/Audi.htm
Again, if you connect the new radio out to amp in - it will burn the amp (assuming the new radio has pre-amp outs)
Old Dec 31, 2009 | 10:28 AM
heyduck's Avatar
Check with Crutchfield.com. I have been a Crutchfield customer/fan since 1980. When you buy your stereo from them you receive a FREE high quality wiring harness adapter as well as a complete color coded wiring diagram. They may even offer a dash kit to clean up the installation.
snoboarder68
Dec 27, 2009 12:37 PM
aluminumpork
Dec 20, 2009 11:44 PM
cokecain
Jun 24, 2009 06:05 PM
Gabriel
Jan 11, 2007 12:19 AM
aluminumpork
Sep 16, 2005 03:54 PM
