Sponsored by:
Sponsored by:
Replacing brake pads
Old 03-30-2009, 07:58 PM
allmet33's Avatar
Default Replacing brake pads
Good evening,
I have found out that I need to replace the rear pads on my '04 A6 Quattro. I found that I am able to remove the caliper and remove the pads with very little effort. However, my question is how do you reset the caliper piston??? On past cars, I would normally take a C-clamp and twist it until the piston is reset to it's full open position. I tried the same thing on the A6 caliper and it didn't budge. Should I be able to reset the piston with a C-clamp???
Feed back is greatly appreciated!!!
Mike
Old 03-30-2009, 09:20 PM
jj2345's Avatar
the same thing happened to me,you need a rear brake tool you will never get the job done without it
Old 03-30-2009, 09:25 PM
Midniteoyl's Avatar
Havent done an 04 a6 before, but usually you can do it with a c-clamp as you said (make sure to remove the cap of the master cylinder )
OR
They screw back in. You need to improvise a tool to do this. There is a slot on each side of the piston to grab with a tool and twist. (Screwing clockwise pushes the piston back into the caliper). The tool could be just a pair of needlenose pliers. Hold the points open to fit the slots in the piston and after a little trial and error you should find a way to hold them to get the necessary torque. (It takes a fair amount of force and the piston should turn slowly and smoothly).
Old 03-30-2009, 09:29 PM
Midniteoyl's Avatar
Heres a good description with pics..
http://www.20v.org/brakmain.htm
Old 03-31-2009, 06:59 AM
bob martin's Avatar
The tool is cheap. Get one. You'll be glad you did.
Bob
Old 03-31-2009, 09:16 AM
Boston Driver's Avatar
THe piston has to turn while being pushed, and there is a special tool for this job. Just go to any AutoZone, and you can borrow the proper tools from them for free (you pay $50 but then get that back when you return the tools). Makes the job SO easy when you have the right tools!
Old 03-31-2009, 09:27 AM
allmet33's Avatar
Default Many thanks!!!
I did see the slots on the piston head that you mentioned. I will be going to get that tool to make life easier.
Anything special I need to know when it comes to replacing rotors???
Old 03-31-2009, 01:46 PM
hxgaser's Avatar
From what I hear rear brakes starting around 2004 require VAGcom to retract the rear brake pistons. You should check. Talk to auditech79
Old 04-01-2009, 01:24 AM
erirod's Avatar
Member
I have a 99 a4 quattro 2.8, do I need to do the "turn piston" thing when replacing the back pads and rotors? or is this just for newer models? Anything in perticular I should know, I've done honda, nissan and domestic rotor and pads in the past. Is it pretty much the same on my 99?
Old 04-01-2009, 02:00 AM
ImTheDevil's Avatar
You will need it for the 99 A4 as well - we have the same setup on our rear brakes. Nothing special at all to know, but you will need allen bits to remove the calipers from the carriers (7 or 8mm, I don't recall which offhand). Other than that, and the caliper screw-compressor, there's absolutely nothing to it. It's a very easy job.
Quick Reply: Replacing brake pads
