replacing cooling fan, help?
Old Mar 8, 2009 | 09:24 PM
little_town_audi_owner's Avatar
Thumbs down replacing cooling fan, help?
first i had a noise coming out of my front passenger side cooling fan, so then i took apart the front end, the shaft of the motor ( fan motor ) is loose causing vibration and noise, the motor is directly wired on both ends from the fan motor to the relay box ( i assume ) , have any of you spliced the wires to replace the motor or what is the procedure, any suggestions?
as looking to replace the fan motor so does anyone know where i would go to buy that
thanks
by the way i own a 2002 audi a6 3.0 quattro
Old Mar 9, 2009 | 04:52 PM
and only the passenger side fan is the one making the noise
Old Mar 10, 2009 | 02:25 AM
chefro's Avatar
There's at least one place where you can find what you're looking for:
___If you're talking about the Blower Motor (AC/Heat Related):
2002 AUDI A6 QUATTRO 3.0L 2976cc V6 FI (T) [AVK] :
Heat & Air Conditioning : Blower Motor
VEMO Part # 4B1820021B {Blower Motor}
Part............... Core..........Total
$214.79......... $0.00....... $214.79
___ If you're talking about the Radiator Cooling Fan:
Cooling System : Cooling Fan Motor
VALEO Part # 8E0959455L {Cooling Fan Motor: Left}
Price................ Core.............. Total
$180.79............ $0.00........... $180.79
VALEO Part # 8E0959455N {Cooling Fan Motor: Right, 300mm Diameter, 200W}
Price.................Core................Total
$219.79........... $0.00............. $219.79
Old Mar 10, 2009 | 02:08 PM
thanks alot! and then would you splice the wire since its all directly wired?
Old Mar 10, 2009 | 03:09 PM
chefro's Avatar
In all the honesty, I never replaced a radiator fan. I like to break down stuff in components (when I have a chance or need) to see how it works, but I never dealt with a fan.
Some of the guys who replaced one may be able to give you a little guidance.
However, I would think you should be able to follow its wiring and see how and where exactly it gets powered.
In addition, if you have a spare car, you should be able to take it out, dismantle it and see if it just needs lubrication - before spending the money on a new one. I have no idea if it is bearing- based or else.
JD_MILLS
May 16, 2012 06:29 PM
LKaler
Jul 26, 2010 11:38 AM
gujo0001
Mar 26, 2008 02:36 PM
jgm7507
Oct 31, 2007 07:33 PM
spasmus
May 22, 2007 09:05 PM
