A/c not cooling
Old May 10, 2012 | 10:19 PM
JD_MILLS's Avatar
Default A/c not cooling
I have an 02 audi a4 1.8t the a/c won't cool on it was recently recharged and has no leaks. the compressor is coming on and off like it should. but the high pressure side is hot then once it passes thru the orfice it gets somewhat cool like it should just not as cold as it is supposed to. replaced the orfice today and made no difference. after a few minutes of idling the high pressure line gets hot on both sides of the orfice. i hooked a gauge to it earlier and the pressure spikes from around 45psi to about 110 every few minutes. anyone got any ideas? or had a similar problem? thanks for any and all help.
Old May 11, 2012 | 01:38 AM
Zachariah's Avatar
High pressure switch, that goes straight into the passenger side A/C condenser is toast.
Old May 12, 2012 | 07:58 PM
JD_MILLS's Avatar
Are you talking about the one that is behind the driver side headlight
Old May 13, 2012 | 08:57 AM
Zachariah's Avatar
Default Correction -
It's behind the passenger side headlight. You might also want to check the freon pressure also. Too much will shut the compressor motor off.
Old May 13, 2012 | 02:25 PM
JD_MILLS's Avatar
There isn't one on the passenger side. its on the LEFT side of the car. and screws into the condensor. i searched on the passenger side for a while and finaly come to the conclusion all the ppl saying it was on the passenger side must be driving from the right side of the vehicle.
Old May 16, 2012 | 06:29 PM
ImTheDevil's Avatar
Right lol. Most of us are in the US. If you're not, fill in the location from your profile and we can avoid confusion.
LKaler
Jul 26, 2010 11:38 AM
devolab
Aug 13, 2009 02:51 PM
ditallow
Mar 31, 2008 06:16 AM
jgm7507
Oct 31, 2007 07:33 PM
neur0tic
Sep 10, 2007 06:24 PM
