Sponsored by:
Sponsored by:
Reservoir vs coolant tank difference
Old 08-10-2014, 10:01 AM
johnny80's Avatar
Default Reservoir vs coolant tank difference
Hi Friends,
I got a stop leak for my audi radiator but I am little confused after reading the instructions.
It's mentioned - cool the engine, remove radiator cap, shake bottle and pour directly into radiator. If direct access to radiator is not available, install in overflow tank. Fill radiator and overflow tank to proper level and reinstall cap.
The confusion - I don't see any radiator cap in my audi and just see a white tank with blue cap which I believe is overflow tank as I put my coolant in it but I also see another tank with yellow cap. Is that for transmission fluid? So, is the coolant reservoir and overflow tank the same thing and I need to put the leak solution and then coolant in the same tank?
Any help would be appreciated.
Thanks,
Johnny
Old 08-10-2014, 10:23 AM
ImTheDevil's Avatar
1 - the black and yellow is the oil.
2 - don't use stop-leak. Find the problem and fix it rather than potentially cause more problems
Old 08-11-2014, 12:08 AM
AnthonySlaughter's Avatar
yellow is brake fluid. Fix the problem
amcase
01-16-2012 12:17 AM
Matthew264
04-27-2009 11:46 AM
GLD
12-06-2008 05:22 PM
a4b5guy
08-28-2008 07:41 PM
Trey25
02-29-2008 01:09 AM
Quick Reply: Reservoir vs coolant tank difference
