reset airbag and Esp lights?
Old Oct 4, 2009 | 03:17 PM
Jackmup's Avatar
Default reset airbag and Esp lights?
I removed the steering wheel and column now I get an AIR BAG and an ESP MIL are they associated some how? I'll check the connections again and look into ross-tech to see if I can reset them with the Vag - com Has anyone reset these? or had this Issue?
Old Oct 4, 2009 | 07:28 PM
TwinTurboC5's Avatar
Default Warning Lights
HI, If you've checked all the connections and they're ok...You might try disconnecting the battery in the car for a while to kill the power supply, and then reconnect it and see if the warning lights are still there.
Old Oct 4, 2009 | 09:05 PM
Jackmup's Avatar
OK, I reset the DTC's in Airbags and I had the steering sensor 360 degrees off (of course I did!) But all is well again.
I love doing things two or three times before getting it right. That way I get really good at it.
bad34
May 1, 2012 06:29 AM
Kmbbond
Apr 3, 2011 06:41 PM
archangel1st
Nov 9, 2010 09:04 PM
aud99
Nov 30, 2006 08:48 AM
bigladnelly
Jan 29, 2003 09:56 PM
