Right Rear Problem, Help
Old Aug 31, 2006 | 02:04 PM
Ice Train's Avatar
Default Right Rear Problem, Help
So I need some help. There seems to be a problem with my right rear tire/suspension. When I hit bumps, no matter how big or small, I hear what sounds like as best I can describe it a cage rattling. It is not a clunky sound, or a thudding sound, but rather sounds like a cheap metal cage rattling. Anybody have any ideas as to what this is and what I have to do to fix it?
Thanks is advance for your help.
Old Aug 31, 2006 | 02:14 PM
SouthboroAudiGuy's Avatar
Default RE: Right Rear Problem, Help
Things to check...
- Muffler hangers
- Insulation surrouncing mufflier (is pretty maleable and can bend and make contact with muffler)
- Belly pan -- if missing screws (common), it can make such a noise
- Trunk (anything rattling around in there?)
Old Aug 31, 2006 | 02:21 PM
Ice Train's Avatar
ORIGINAL: SouthboroAudiGuy
Things to check...
- Muffler hangers
Ha, yeah the first thing I did was look in the trunk. So what do you think I should do, just get under the car and try and move stuff around?
Old Aug 31, 2006 | 02:23 PM
ORIGINAL: Ice Train
Yup. Eliminate the easy stuff first. If you still have problems, c'mon back and we can go from there.
Old Sep 3, 2006 | 02:53 PM
dankhound's Avatar
Check the lisence plate braket and make sure its tight. Sometimes they have a metal frame that makes that kind of noise. Also check to make sure the rear brake pad springs arent broken. You can also use a can of lubricant to spary parts of the suspension. If you spary something and the noise goes away you have your culprit.
Old Sep 3, 2006 | 07:07 PM
Ice Train's Avatar
Well I looked under the car and banged on some stuff, no luck. I had to get it inspected so I did that and asked them to lift the car up and look under it, they banged some stuff, no luck. If it is the liscense plate why is it only doing it when one side of the car goes over a bump but not the other. It needs to be detailed anyway, I guess I will just have the Audi dealership look at it.
Old Sep 3, 2006 | 07:08 PM
Ice Train's Avatar
ORIGINAL: dankhound
How do I check to see if the springs are broken? And what should I spray on the suspension? What type of lubricant?
Old Sep 4, 2006 | 02:28 AM
dankhound's Avatar
Depending on your wheels you may be able to reach your hand in and touch the pads thru the top of the caliper. They should should be tight in there. If one or both are loose they can make the sound you describe. As for the lube to use just about any gerneric lube should work. Something like wd40 in a spray can.
Old Sep 21, 2006 | 11:41 AM
Ice Train's Avatar
So I am brining the car in to get some work done next week and to check out the rear wheel problem. But I was pumping gas last night and decided to kick the tire to see if that made the same noise as when I am driving...and it does. When I kick the rim however there is no noise but that same high pitched rattle is there just by kicking the tire, now I have no idea what it is...not like I did before.
rj.r1005
B7 Models
Nov 18, 2012 12:22 PM
NLE76
Jan 26, 2011 05:09 PM
DrBeaker
Nov 17, 2010 11:35 AM
banddr2
Aug 26, 2009 11:44 AM
300zxracing91
Mar 6, 2008 11:36 AM
