rough idle after filling up with gas
Old Nov 21, 2010 | 01:31 PM
hankeester's Avatar
Default rough idle after filling up with gas
2000 Audi A6 Avant.
I have this weird problem that everytime I fill the Audi up with petro, it starts roughly then goes away within a couple of seconds. Sometimes I have to crank it twice for it to start.
Any ideas?
Old Nov 21, 2010 | 10:04 PM
bigdadi's Avatar
Maybe the gas quality. Try out a tank of name-brand: SHELL 93 Octane to see if any difference.
Old Nov 21, 2010 | 10:24 PM
briesa4's Avatar
change your fuel filter and try not to vapor lock it
Old Nov 23, 2010 | 11:36 AM
hankeester's Avatar
it's not a gasoline quality issue as I've tried using high grade before. I'll change the fuel filter but what's the vapor lock all about?
Old Nov 23, 2010 | 12:52 PM
briesa4's Avatar
Its running your car completely to "e" or empty and over filling it. It creates a sucking action and with you remove your gas cap it may be tight or hard to even turn.
It will throw a code pertaining to your fuel tank and can actually cause failure in your pump.
Old Nov 23, 2010 | 01:00 PM
hankeester's Avatar
ah yes, the V.L. I don't often do that but will keep an eyeball on it. Audi's are always throwing codes though, they're very....
tem·per·a·men·tal/ˌtemp(ə)rəˈmentl/Adjective
1. (of a person) Liable to unreasonable changes of mood.
2. Of or relating to a person's temperament: "they were firm friends in spite of temperamental
Old Nov 23, 2010 | 01:04 PM
briesa4's Avatar
Trust me I feel your pain!!!
Definitely wasnt the smartest buy but is a ton of fun!!
Old Nov 23, 2010 | 01:08 PM
hankeester's Avatar
I recently sent in the ABS Module for a rebuild along with the display with the garbled message center. Now I only have one light on (C.E.), doesn't look like such a Christmas tree.
I repaired a display on a very pristine 100 that I had but sent the A6 display in for the repair.
Old Nov 24, 2010 | 01:05 PM
padog's Avatar
Do some searching here and at Audiworld I have read threads at one or the other on this problem it has to do with your charcoal filter filling with fuel and pushing fuel back through to the intake causing your engine to flood itself when you refuel.
Be sure when you refuel to stop fueling when the nozzle clicks off because trying to top off the tank seems to lead to the problem your having. The charcoal filter is located under the spare tire well underneath the car there is a plastic cover on it they say if you remove it and it is rather heavy it is full of fuel and needs to be changed out.
Old Nov 24, 2010 | 01:12 PM
padog's Avatar
Ok just did a quick search and found this thread it will help you more than I can take a look at it!
https://www.audiforums.com/forum/sho...harcoal+filter
