RPM fluctuation
Old Jan 27, 2013 | 10:53 PM
toolagit2qwit's Avatar
Default RPM fluctuation
Hello. A6 2.8. W/ 200k. Recently, the engine or rpms has a slight erratic rev while driving between 30-40 mph or at cruising around 70. The rpm needle moves north about 100 rpms. Meaning if I am cruising at 2300 rpm the engine will rev to 2400 then back, etc....I am not pushing then letting up on accelerator but it sounds that way.
- replaced spark plugs, wires, gas filter, crankcase hose, Pcv,air filter and cleaned air mass sensor
Note.
- Tranny shifts perfectly and fluid changed every 60k.
- 8 weeks ago I got two misfire codes on cly 1 & 2. Code has never returned.
My initial thoughts on what could be causing this flux is fuel injectors or ignition coil?
Would appreciate any thoughts on what could be causing this.
Old Jan 29, 2013 | 01:46 AM
ThePoorCollegeStudent's Avatar
I have the same problem with my A4, and I was told that it may be a bad O2 sensor in the exhaust. I haven't actually gotten it fixed yet, as it only acts up some times and only when idling, so I'm not 100% sure
abetz470
B7 Models
11
Dec 19, 2022 05:50 PM
My Ryde
Jun 10, 2010 04:54 PM
jaymson
Sep 6, 2008 02:59 PM
jchaffee1
May 2, 2008 02:22 AM
richpenney
Nov 4, 2006 08:39 AM
