Seat Malfunction help
Old Dec 28, 2014 | 02:50 PM
richie70's Avatar
Default Seat Malfunction help
Allroad same as A6-S6 c5.
2005 Audi Allroad, c5, w/memory driver’s seat. Had never had any problems with seat and it was in my wife’s position which is forward from mine and it would no longer move back to my position. I checked for loose wires and found nothing. When I tried to move with the forward–back switch it would only move forward. The up-down and tilt would not work. Noticed that the interior lights would dim when moving any of the switches on the side of the seat except when moving the seat forward. Took the forward-back motor loose and moved the switch it still would only rotate forward movement and would dim interior lights when switched for back movement. Removed the seat and checked that nothing was binding and found nothing. Used drill to drive seat back, reinstalled motor and seat. Still unable to get any movement except forward movement. Check with Vag-Com got this error code “01191- Motors for seat adjustment, 44-00 – short circuit”. Confusing as to what may be wrong. Anyone had same problem and what was the fix?
Old Feb 11, 2015 | 02:16 PM
richie70's Avatar
Default problem solved
The problem with my seat turned out to be with a motor wire on the seat back motor. The lumbar mechanism has a heavy support wire that goes from one side of the seat frame to the other. This had broken on one side and rubbed through the insulation causing a short. Since the only time it had power was when you pushed one of the switches that moves the seat but it would not cause a fuse to blow. Replaced the wire from another seat and repaired the wire. All is good.
richie70
Dec 28, 2014 02:49 PM
immusicman
Nov 2, 2010 08:39 PM
nebdesign
Oct 1, 2010 05:09 PM
ugadawg24
Apr 4, 2007 06:01 PM
John Drivesabox
Mar 24, 2007 07:10 PM
