Secondary Water Pump question
Old Feb 12, 2007 | 05:23 PM
pkhuman78's Avatar
Default Secondary Water Pump question
As I said in my other post I had a new buyer check done at the local stealership. Upon closer reading of what they found "wrong" with the car they have listed that the secondary water pump is going out / leaking.
I understand that this is a common issue in the turbo cars. My question is this, because the pump is leaking or "weak" does that mean that it needs to be replaced?
If it is a replacement issue where would be a good place to get one and what is considered a "fair" price? Also does anyone know what the projected amount of time is to fix this?
Thanks once again.
Old Feb 12, 2007 | 05:36 PM
Mac_17's Avatar
Default RE: Secondary Water Pump question
I just did it. Pump is $120. The labor is about 4 hours because they have to take everything apart to get to it.
Jason
Old Feb 12, 2007 | 05:48 PM
Innie's Avatar
My fan clutch went out and vibed my water pump to death 1 yr after first replacement.
Check yours.
I paid $700 or so.
Old Feb 14, 2007 | 12:29 AM
ppgoal's Avatar
If you're talking about the auxiliary water pump, I just had mine replaced. $114 for the part and 3 hours labor.
Vehicle was leaking from the rear ofthe engine and Ithought it was a head gasket. A little radiator sealer made it go away. When they did my clutch last week, they saw it was the source of the leaking and replaced it for me.
I probably would not have replaced it if I wasn't doing the other work. I had not noticed any loss of coolant for over a year, although I occasionally smelled somehot coolant after high speed runs. PS - The car also has 89K on it.
Old Feb 14, 2007 | 04:42 PM
pkhuman78's Avatar
Thanks for the input guys. I haven't even smelled coolant, it was just per stealership that I know that it is "going out."
I'm getting ready to have to tear down and replace the valve cover gaskets, is the aux water pump something I should go ahead and do since I'm going to be so far into the motor?
Where did you guys get your pumps?
bob martin
Feb 12, 2011 11:56 AM
mlwartman
Jul 12, 2010 11:28 AM
thareals4
May 18, 2009 05:20 PM
hidnmine
Apr 18, 2009 03:08 PM
caddy2audi
May 12, 2008 05:06 PM
