set TDC without tearing the front apart
Old Apr 6, 2007 | 05:07 PM
wings7351's Avatar
Default set TDC without tearing the front apart
Hi, I'm about to change my cam tensioner seal and valve cover gasket. Fron the discussions in the forum, I need to put the engine at TDC however last time I did that was when I changed my timing belt, in which I had to remove everything in front of the timing belt. Do I have to the same thing here or there is other way to set it in a quick way?
Any advice is appreciated.
Old Apr 6, 2007 | 05:17 PM
techbod's Avatar
Default RE: set TDC without tearing the front apart
there is no quick way do it as the picture says that I posted otherwise it could cast more than you think if not lined up right
https://www.audiforums.com/m_478033/.../tm.htm#478339
Old Apr 6, 2007 | 11:18 PM
mpw2.7T's Avatar
You do need to get to near top dead center, or you won't be able to compress the tensioner adequately. What I did was just watch the tensioner while I was turning the crank bolt. You can see the tensioner rise and fall. I stopped when it was at the highest point. I don't believe there is a requirement to be exactly at TDC.
Old Apr 8, 2007 | 02:19 PM
SSn's Avatar
SSn
There are two TDC marks under the valve covers inside the engine for proper Cam alignment.
Old Apr 9, 2007 | 04:01 AM
wings7351's Avatar
I changed passenger side cam tensioner seal today; however when I moved to the driver side, I found out that the tensioner did not rise as much as the other one at passenger side; I put in the compression tool and I got barely any room to more the cam tensioner around to even pull the steel gasket out; of course I could not swap the rubber gasket either because of this.
Is there a different TDC for the driver side? Or the driver side just won't rise as much? Mine is a 99 A6 2.8L. Thanks for any input.
Old Apr 9, 2007 | 06:14 AM
mustang196718's Avatar
top dead center is top dead center with respect to the entire engine, not just one side or the other, so no, there isn't going to be a seperate tdc for the other side. i suppose the possibility that the drivers side just doesn't move as much. sorry, i'm definitely no expert on the 2.8s, but hopefully my input will help you a bit.
Old Apr 9, 2007 | 09:10 AM
mpw2.7T's Avatar
Turn the crankshaft over a couple times and stop when the tensioner is at the top of its motion,
Old Apr 9, 2007 | 01:44 PM
wings7351's Avatar
thanks mpw2.7t, when you did the job, did the same thing happen to you? I'm just wondering why this is happening.
Old Apr 9, 2007 | 10:57 PM
mpw2.7T's Avatar
Yes, I had the same thing happen. I don't know how that system works, but I do know that when you turn the crank, the adjuster cycles up and down. If you leave it in the uppermost position, you will get the slack you need to remove the seal and clean the area.
Good luck!
Old Apr 10, 2007 | 02:19 AM
wings7351's Avatar
Thanks to everyone. I put the bolts back onto the tensioner assembly, turned the crank shaft, and it did rise up and down. The top position is not on TDC, but somewhat 90 degrees more on the cam shaft.
mpw2.7t, I guess it did not rise up yesterday when I turned the crack shaft was because I had the bolts loose when I did that. Does it make sense? what's driving the tensioner up and down?
Zer0
Aug 22, 2012 02:19 PM
brrman
Apr 16, 2009 04:26 PM
mustang196718
Apr 6, 2007 05:15 PM
S obsessed
Mar 21, 2007 04:29 PM
rbrtech
Jan 18, 2006 06:14 PM
