Should I Sea Foam?
Old Jan 10, 2010 | 02:23 PM
sydmik08's Avatar
Default Should I Sea Foam?
I have seen some posts about Sea Foaming your car and how good it is for the car. I wanted to see what others think about this and if I should give it a shot. I have an '03 A6 3.0 with over 150,000 miles on it, well maintained. I am not that mechanically inclined and I don't want to screw up my car. So should I give a shot and Sea Foam my car?
I looked at the steps to do this on-line and the first steps are easy, but the last ones are where I am worried I will screw up the car.
Any thoughts?
Old Jan 10, 2010 | 04:46 PM
dannyghost's Avatar
Member
if guru says its ok....well, its ok.
https://www.audiforums.com/forum/sho...d.php?t=112161
Old Jan 11, 2010 | 12:36 AM
hxgaser's Avatar
Seafoam is a great product, but expect some new oil leak after use especially on a high mileage vehicle.
Old Jan 11, 2010 | 05:25 AM
dannyghost's Avatar
Member
Old Jan 11, 2010 | 06:22 AM
WoodShoe's Avatar
Seafoam is too good. It will prolly give you an oil leak from cleaning crud out of some of your gaskets.
Old Jan 11, 2010 | 02:20 PM
ppgoal's Avatar
Good post. I keep looking at Seafoam every time I'm in the auto section of Walmart, but I'm afraid of oil leaks or creating problems by breaking crud loose in the engine. I've changed oil every 8-10k for 160k miles so I thinki I'll stand pat.
Are there similar risks if you just add, say 1/2 a can, to your gasoline?
Old Jan 11, 2010 | 02:33 PM
hxgaser's Avatar
I never had any issues with adding Seafoam to gas and running it through the intake. I normally replace the fuel filter and spark plugs after I do the gas tank and the intake.
Old Jan 11, 2010 | 02:36 PM
hxgaser's Avatar
Originally Posted by dannyghost
They are not necessarily being untruthful. Seafoam will not harm gaskets and etc. The issue is that high mileage vehicles have buildup which dries out gaskets. So when the build up is removed, the old gaskets fail. So in reality, they are not lying.
I actually really like Seafoam. I just expect to replace a few gaskets when I do it on a used car. For all the cars that I have owned for awhile, I actually use Seafoam pretty regularly in the crank case. The whole point is to keep gunk from building up so that the gaskets stay pliable.
Old Jan 11, 2010 | 02:46 PM
sydmik08's Avatar
Thanks for the replies. I am just hesitant because like I said I am not that mechanically savy, so if I do this, I am not sure I can replace the gaskets myself. I did replace gaskets years ago on an older car, but it has been a long time.
hartsoe1
Feb 21, 2012 08:25 PM
diggs
B7 Models
Mar 25, 2010 02:01 PM
nitro_rider2001
Sep 25, 2008 04:17 PM
BLK_A4
Dec 20, 2007 10:08 AM
StepUpProductions
Feb 13, 2006 01:29 AM
