Smoke on the Passenger side engine compartment
Old Jul 6, 2011 | 05:29 PM
dbelnap12's Avatar
Default Smoke on the Passenger side engine compartment
I have a 2001 A6
The check engine light came on a few days ago and I found out that it was the secondary air pump. I have heard that you can replace a fuse or relay and that can fix it or a hose might be clogged? Any suggestions or comments?
The smoke I can see when stopped and the car is running or right after I have shut it down comes from the passenger side. I looked underneath and it looks like there is an oil leak. I have no idea where it would come from. I have been reading other posts on here and some say tightening the valve covers can fix this problem? Suggestions, comments?
Old Jul 6, 2011 | 06:40 PM
hxgaser's Avatar
Usually the source of the secondary air pump code is related to vacuum hose failure. Do a search for vacuum line/hose and you will find a ton of info.
As for the smoke, you most likely have a leak from the valve cover gasket. It is pretty straight forward DIY. Another suspect oil leak spot is from the cam seals and the tensioner gasket/seals. These are more involved.
WigReis
S4
Apr 18, 2015 04:52 PM
Waudi05
Feb 19, 2013 10:00 PM
sagarh
Jun 12, 2009 02:33 PM
wings7351
Mar 9, 2007 01:52 AM
