Some questions about the variable intake manifold
Old Sep 28, 2015 | 09:22 PM
levansula's Avatar
Originally Posted by nemohm
The only difference reported - you'll notice after the replacement - is the reduced weight of your wallet.
I had the same issue on my 02 b6 a4 3.0 - eventually both arms of the change-over mechanism snapped and the rotary valve was stuck on the long intake tract. From my experience, dealers will either charge you >$560 for that part or make you buy a whole new intake manifold ('bout $1,300). No way.
I eventually totally ripped out the rotary valve, leaving the manifold hollow. Theoretically, this would hinder induction by permitting destructive interference and causing harmonic and volumetric imbalances between cylinders. Personally, I have to say, there's no real noticeable difference. If I had to say something, I'd say there's a small improvement in pull >5000 rpm, and a very slight loss of torque between 3-4k rpms, but it's soooooooooooo slight that it's possibly all psychological. There's no check engine light or anything - the car runs as smooth as ever, fuel economy is normal (and I've been using this as a daily driver for quite some time).
Honestly, I can't imagine the vehicle performing much better, even if the manifold was fully operational. If the day comes when I buy a new actuator assembly or somehow repair the old one, I'll be here to confirm. But until then, I wouldn't make fixing this a huge priority.
Of course, it is possible that my car was just so FUBAR to begin with that this one little thing makes no relative difference. Food for thought.
RaivisGertners
Nov 11, 2018 11:15 AM
David Narez
Jun 26, 2013 09:20 AM
hellperados
Jun 4, 2013 07:06 PM
anmagro
Jan 8, 2008 11:05 AM
True_Pinoy
May 5, 2006 06:54 AM
