Sport Mode with 3.11
# Open software and connect to the car.
# Turn the ignition on, but leave engine off. The transmission cannot be recoded with the engine running.
# See Main Screen, and click on Select Control Module: Select.
# See Select Control Module screen, and click on 02-Automatic Trans.
# See an Open Controller Screen, and select Recode-07.
# See Recode dialog, where you can enter new numbers for transmission software coding (and workshop code). Select "Do it". More information on the codes can be found here.
# You should again see the Open Controller Screen, with the new code showing.
# The transmission is recoded. You can exit the windows by selecting Go Back two or three times.
# Turn off car and disconnect
* copied from "http://www.audipages.com/Tech_Articles/auto_transmission/codingtransmission.html"
Also see post #7 here :http://forums.audiworld.com/showthread.php?p=14768000
A little more :http://forums.audiworld.com/showthread.php?p=14747775
Thanks! I actually just figured it out though :P There is a misleading post on this forum that tells you to go into adaptation, thats why I got screwed up. Hopefully this post clears it up for vag noobs like myself.
