Sticky Door Handle
Old Aug 31, 2009 | 01:04 PM
copper07's Avatar
Default Sticky Door Handle
98 A6 Quattro, 141k
On my passenger side door, to open it form the outside you have to pull the door handle twice in order for the door to open. The door opens form the inside just fine.
What can I do to make the door handle work better?
Thanks
Old Aug 31, 2009 | 01:52 PM
ppgoal's Avatar
I have a similar problem with my driver's door handle. Someone who is a better mechanic than I (not an hard challenge) may have a more high tech solution, but I purchased some dry lubricant and I sprayed the heck out of the mechanism. It works better for a while, but then it does start sticking again. Repeat process.
Old Sep 2, 2009 | 08:52 AM
aliyork35's Avatar
you should take your car to the mechanic. there is minor fault in it and it can be easily repaired
Old Sep 2, 2009 | 12:37 PM
copper07's Avatar
If it is a minor fault I would like to fix it myself.
Old Sep 2, 2009 | 12:50 PM
Jeffla's Avatar
A couple years ago I replaced my drivers door latch because my car no longer acknowledged when I opened the door. IIRC, there was an adjuster screw in there to align the door handle pull. I could be wrong, but I remember having to adjust it on the new latch and now my drivers door has the same amount of travel/pull as the rest of the doors.
Pop off your door panel and check it out. The door panels are extremely easy to remove.
If I am completely wrong, oops, sorry now.
Old Sep 2, 2009 | 04:26 PM
NH_USA's Avatar
I'll have to look into the handle adjustment --
I have been using WD-40 and graphite lube when the doors became hard to open
Old Sep 2, 2009 | 10:36 PM
james0013's Avatar
Is the amount of force required to open the offending door related proportionally to the temperature outside?
I find my drivers door difficult to open in hot weather I sprayed the latch with a spray lubricant and that seemed to help a grate deal.
Old Sep 3, 2009 | 03:55 PM
copper07's Avatar
It does not matter if it is hot or cold out side.
I have to pull the passenger door handle twice. Doesn't matter how hard the handle is pulled the first time, it still has to be pulled twice to get the door open.
Old Sep 21, 2009 | 04:26 PM
copper07's Avatar
Any other ideas?
audi guru
Jun 6, 2013 04:39 PM
bauer1185
Apr 30, 2009 03:02 PM
baconkid92
Feb 18, 2009 04:07 PM
Hotazlava32
Jan 30, 2008 11:37 PM
auDi1.8TQ
Apr 28, 2005 12:25 PM
