strange noise
Old Dec 2, 2008 | 12:35 PM
hcaudikeed's Avatar
Default strange noise
ok i just had my tie rods replaced and an alignment done. i need to replace the outer cv boots, and will be doing that shortly. i got the tie rods done on wednesday and on friday the front right started making a strange noise when going at low speeds. the only thing i can compare it to is the noise a coffee maker makes when it starts pouring the coffee into the pot. know what i mean? it is only in the front right of the car, and happens when i accelerate from going slow or stop, when coming to a stop, or just coasting at low speed. any help?
Old Dec 2, 2008 | 01:30 PM
bob martin's Avatar
"when it starts pouring the coffee into the pot"???? You mean a dribbly liquid kind of noise?
Bob
Old Dec 2, 2008 | 01:31 PM
hcaudikeed's Avatar
like the sort of purring noise that it makes, u know?
Old Dec 3, 2008 | 12:12 PM
NH_USA's Avatar
Probably crap in the rotor
Old Dec 4, 2008 | 11:00 AM
hcaudikeed's Avatar
if that was the case, wouldnt the noise be amplified when braking tho?
Old Dec 4, 2008 | 12:49 PM
NH_USA's Avatar
Mabe not... I had a vehicle whose brakes made strange noises (like you describe) when I went slow. But there was no noise at speed or when braking. Later we found that some crud had slipped behind the calipers and caused them to be a bit loose thus they made funny noises because they vibrated.
Old Dec 4, 2008 | 09:08 PM
hcaudikeed's Avatar
i guess ill give that a check then. cause the only other thing i could think of is suspension related, and the mechanic that did my TRE's said my control arms and such were perfectly fine. thanks alot buddy.
kwiniarz
Aug 15, 2009 08:03 PM
wainakh
B7 Models
Jun 4, 2008 02:05 AM
west2005
Aug 11, 2006 03:29 AM
rjplunk9
May 4, 2006 09:27 PM
visual_e
Jun 9, 2005 11:26 AM
