Strange noises
Old Jul 21, 2006 | 04:57 PM
madridlover's Avatar
Default Strange noises
Hello everyone,
I'm hoping someone out there may be able to help me out on this one. I have a '98 A6 2.8L Quattro and for the last several months I've been experiencing a strange noise coming from the front of the car. This noise is not always there but seems to be more apparent after the car has warmed up and during hot summer days (expansion of some parts???).
It is a strange thumping sound but the sound doesn't increase with speed and occasionally occurs when we turn the steering wheel. It also happens while moving straight and during braking. IN fact, the noise can be felt through the gas and brake pedals. I realize that without acutally driving the car it may be a bit difficult for someone to diagnose this problem however it's one of those problems that when i take it to a mechanic to hear the noise....the noise misteriously disappears. That was a couple of months ago but now the noise has gotten worse so I think whatever is failing and causing the noise is getting worse.
Could it possibly be the CV Joints? Or a problem with the steering rod??? Or do i have a problem with the front axle??
Any help will be greatly appreciated. I may take it to my mechanic over the weekend and have him listen to it again...
Thanks in advance.
Old Jul 21, 2006 | 06:19 PM
techbod's Avatar
Default RE: Strange noises
you need to drive it?? anything warped would increase in vibration on speed so cant think of anything that would do otherwise
Old Jul 22, 2006 | 07:07 PM
BGPilot's Avatar
One thing that you can simply check (if you haven't already) is flat spots on the tires.
Sometimes it just takes the tires to warm up (15min or so) for the flat spot to go away, or it may be more permenant such as a skid or physical breakdown of the tire (steel belts on the inside).
Brian
rocky_mtn_a4
Aug 23, 2011 09:30 PM
scotts custom
Apr 21, 2009 07:22 PM
AML 225
Sep 27, 2006 12:09 AM
jake_beahan@hotmail.com
Apr 12, 2006 11:54 PM
yoon
Jun 15, 2004 12:33 AM
