subwoofers in and now one touch feature does not work
Old Sep 13, 2006 | 09:53 PM
thetryal's Avatar
Default subwoofers in and now one touch feature does not work
i just done installing my subwoofers. i had the windows rolled down while installing it to give me a draft. when i finally got everything back together i went to roll up my windows. i tapped each button and nothing. i had to hold each up and down. does anyone know how to correct this? is it possible to correct it with a vag? thanks
Old Sep 13, 2006 | 09:59 PM
craig_mack's Avatar
Default RE: subwoofers in and now one touch feature does not work
Did you have the key turned on when you tried to roll up the windows.? If you were just using the retained power feature, the windows lose their 1 touch feature.
Old Sep 26, 2006 | 07:13 AM
houndz's Avatar
Member
Your battery was disconnected.
To fix:
For each individual window switch at the driver door, hold the switch down until the window stops. repeat in the oppisite direction. Do this with all switches. One touch feaature reappears.
Send me a 12 pack when you get this to work.
FishEye
May 11, 2012 02:28 AM
2009A42.0t
B8 Models
Apr 27, 2009 10:36 PM
dblock110
Nov 12, 2006 04:21 AM
