Super Charging a 2.7T
Old Jun 8, 2009 | 04:22 PM
james0013's Avatar
Default Super Charging a 2.7T
Like every other 2.7T owner I live in fear and dread of the day when my turbos will go and i am faced with a big bill for there replacement.
I was looking around the forums today and saw a supercharger fitted to a 2.8 A4 Avant. Now we know that the 2.8 and the 2.7 are to an extent the same engine, also we know that one of the problems with turbos is (dare I say it the L word) lag.
So give your opinions, my plan would to be when that fateful day comes and my turbos blow out to do the following:
Remove the old dead turbos and fit the maifold from a 2.8 model. Then fit a supercharger to the 2.7 block. Anyone think this is possible?
Thanks in advance.
James
Old Jun 9, 2009 | 05:22 AM
jallen3521's Avatar
Turbo lag is not a big deal in the 2.7T It spools up fairly quick that I have noticed. As for supercharging your 2.7 I am sure it is feasible, with money you can do anything you want!
Old Jun 9, 2009 | 01:20 PM
cbock's Avatar
There isn't much lag in our cars IMO.
You would end up spending at least as much to put a SC in. And, it would most likely pump out less HP than a properly tuned K04 upgrade.
Don't do it.
Old Jun 9, 2009 | 01:22 PM
cbock's Avatar
Oh, and only half of me "fears and dreads" that day. The other half CANNOT WAIT!
Old Jun 10, 2009 | 02:25 AM
trapped's Avatar
Hahah so true. I mean in my opinion blown turbos would suck the big one, but i mean if your going to pull the engine why not put on some Ko4's, fueling, and all the goodies to go full stage 3????
Old Jun 10, 2009 | 06:09 PM
ppgoal's Avatar
From what I've read, oem K03s and labor might set you back $2-3k, if that. Doing K04s right, with different injectors, piggies, will cost $6-8k.
I have a supercharged Crossfire SRT6 and while it pulls strongly from lower rpm, the chipped A6 seems to pull a lot harder especially when it hits its power range above 3500 rpm.
IMHO, a supercharger will cost a hell of a lot more than replacing the turbos because so many other things will probably have to be changed, including reprogramming the ECU which is dang difficult.
Old Jun 11, 2009 | 11:23 AM
AutoUnionFan's Avatar
If your worried about blown turbos and are considering a supercharger, why not just sell the 2.7t and buy and 2.8 and supercharge that?
Old Jun 11, 2009 | 10:35 PM
plainaudiguy's Avatar
Default Off topic for a second
You and I have have similar setups. My chipped A6(tip) currently surges up top. I am putting in 710Ns this weekend :-). I have a C32 AMG which has the same engine as your Crossfire, and that things pulls pretty good all the way through the range. I am not sure if the Crossfires have the traction control, but that thing sucks power. When I turn it off, my jumps from 60-100 are considerably faster than my A6. I will get a better judgement after this weekend. Sorry to go offf topic.
Old Jun 12, 2009 | 01:28 AM
GDET09's Avatar
K04s = D
powereli
Dec 2, 2014 10:50 PM
4plaay
Feb 24, 2010 01:57 PM
30vQuattro
Aug 15, 2008 10:46 AM
ezlnh8u
Jul 1, 2008 03:40 PM
diesel Power
Mar 16, 2006 01:15 PM
