a suspension/springs question
Old Feb 16, 2003 | 02:10 AM
drumn321's Avatar
Default a suspension/springs question
<FONT face="Verdana, Arial, Helvetica, sans-serif"><FONT size=3>I drive a 1999 A6 2.8L Quatro. I'd like to lower it for a sportier look. I have looked into Eibach and H&amp;R springs. Are there any other brands that I should look at? What is the optimum lowering distance so that it looks good but I won't have to worry about it bottoming out all the time? And, if I replace the springs will I have to replace the suspension to because it is so soft?</FONT></FONT></P>
Old Feb 23, 2003 | 04:39 PM
mpuzach's Avatar
The Eibachs are the best choice. They're springs and dampers (shocks) are specifically built for each specific model of A6 and many have raved about their quality. </P>
You can go to Eibach's web site and get the exact part numbers for your car. They make springs which will lower about 1.2" as well as custom dampers designed to work perfectly with the lower springs. The "Pro System" includes both. Most people I've spoken with suggest replacing dampers at the same time as springs, since there's no additional labor involved and the demands of the new springs will usually wear out the OEM dampers rather quickly.</P>
http://www.eibach.com/index1.htm</P>
Old May 23, 2003 | 05:26 PM
Deleted User's Avatar
Default [Deleted]
[Deleted by Admins]
Old Sep 26, 2003 | 04:27 PM
Default [Deleted]
[Deleted by Admins]
fresh1
May 7, 2004 04:33 AM
ejs23
Mar 16, 2004 05:06 PM
Goonercats
Feb 18, 2004 06:31 PM
BoostedA4
Oct 4, 2003 01:52 PM
WickeDA4
May 14, 2003 07:27 PM
