tail gate trim removal
Old May 19, 2007 | 01:26 PM
jlewis166's Avatar
Default tail gate trim removal
Hi. I need a little help.
I need to change a tail gate light bulb on my 2000 A6 Avant. I have directions for changing the light bulbs but they say "remove rear lid lower trim" and it is not at all clear how to do that without breaking anything. I removed the license plate and the license plate carrier but nothing seems obvious about how to remove the trim.
Any advice? Pictures help.
Old May 19, 2007 | 04:47 PM
techbod's Avatar
Default RE: tail gate trim removal
Removing and installing tailgate trim
1-
Lower tailgate trim
t
Removing
Unscrew bolt -3- (1x).
Unscrew bolt behind hazard warning triangle
Pull lower tailgate trim -1- slightly off tailgate.
Unclip lower tailgate trim -1- at fasteners -6- (8x) (unfastening sequence
Press out light -8- from inside.
Unplug connector to light -8-.
t
Installing
First position lower tailgate trim -1- at rear window and then clip in.
Make sure grip moulding -4- is also attached with bolt -3- (detail view A).
2-
Upper tailgate trim
q
Lower tailgate trim -1- removed
t
Removing
Unclip retainer tabs -7- on left and right.
Unclip upper tailgate trim -2- by jerking slightly at fasteners -6- (7x).
t
Installing
Before installing upper tailgate trim -2- make sure rubber buffers -5- (10x) are fitted.
First guide upper tailgate trim -2- behind side tailgate flanges.
Clip in upper tailgate trim -2- first at top and then at sides.
3-
Bolt (1x)
q
Tightening torque 5 Nm
4-
Grip moulding
5-
Rubber buffer (10x)
6-
Fastener
7-
Retainer tab
8-
Light
[IMG]local://upfiles/12092/60EBDCCF9875494F930F98EA79EC4B2E.jpg[/IMG]
Old May 19, 2007 | 05:14 PM
jlewis166's Avatar
thank you, Dave. I'll try that.
Lion61
Apr 12, 2014 12:48 PM
Nevalite
Apr 5, 2010 10:46 AM
bronxblaza117
Apr 10, 2008 06:18 PM
DanBarry
Jul 17, 2007 09:36 AM
