Temperature Flap Motor PHOTO
1995, A6, 2.8L.Noheat condition was caused by temperature flap not moving. Installed new Flap motor and now flap is moving properly and heater is working fine. I don't know if the flap itself was stuck or the motor was stuck. I took motor apart and it appears to be working. All the gears mesh and rotate properly. I added some silicone grease to the gear teeth and closed it back up. Seems to work ok.
The plug has five pins. Pins 1 and 2 are thevoltage pins. It seems that reversing12V (minus and plus) on these twopins makes the motor move to it's full travelin both directions.
Here are some photos of the Temp Flap motor housingwith cover removedshowing it's associated gears, variable potentiometer and plug. Also2 photoswith cover back on.
[IMG]local://upfiles/25667/EAEE26578B7241288A3CCB398D89CD6D.jpg[/IMG]
[IMG]local://upfiles/25667/5B7EB61CF1B04A2BAF25D865AF816ABA.jpg[/IMG]
[IMG]local://upfiles/25667/9350E8B9D5E446E5BC1EA7E8AF24A253.jpg[/IMG]
ericcota2003
Dec 2, 2010 11:18 AM
a6, audi, bracket, check, code, cover, flap, imglocalupfiles256679350e8b9d5e446e5bc1ea7e8af24a2 53jpgimg, localupfiles256675b7eb61cf1b04a2baf25d865af816abaj pg, localupfiles25667eaee26578b7241288a3ccb398d89cd6dj pg, localupfiles25667f8732db648a746b8a2c93052334142f9j pg, motor, temp, temperature, v159
