Are these points good for jack/jack stand?
Old Nov 25, 2007 | 11:13 AM
chromatin's Avatar
Default Are these points good for jack/jack stand?
Hi, stole the picture somewhere else and marked positions 1, 2 & 3. Those places look sturdy and convenient for jacking up the car (2000 a6 2.7t) with mysmall floor jack (unfortunately) and jack stands. I wonder if they are safefor the purpose. One guy did mention that he did use 1 for stand. Thank you very much!
[IMG]local://upfiles/44237/ECE6F82D2A3A4512BA8651040CC309E5.jpg[/IMG]
Old Nov 25, 2007 | 11:20 AM
techbod's Avatar
Default RE: Are these points good for jack/jack stand?
2 is best
Old Nov 25, 2007 | 11:44 AM
chromatin's Avatar
Thanks! Always feel good with an answer from a tech certified. How about floor jack at 2 and then jack stand at 3? Thanks! I feel that is the best way to jack up my car with my tools.
Old Nov 25, 2007 | 11:50 AM
techbod's Avatar
personally I use the bolt as a guide
[IMG]local://upfiles/12092/C6453B11A78945AEB45475BE57315956.jpg[/IMG]
Old Nov 25, 2007 | 11:58 AM
chromatin's Avatar
Yes, I saw this picture also. I got somewhat confused though. First, how can you jack up the car and then put the jack stand in almost the same position? Second, I looked at those positions yesterday but they appeared to somewhat soft. Did I look at the wrong positions, maybe? Anybody has a close-up picture? Thank you very much!
Old Nov 25, 2007 | 12:06 PM
techbod's Avatar
depends on the jack I use a 3ton but in most cases you can fit the Axel stand within reach of the lift point ( you could use the Axel stand as a safety issue and locate it on the chassis
Old Nov 25, 2007 | 12:07 PM
techbod's Avatar
and use the jack as a load holder
Old Nov 26, 2007 | 12:34 PM
SilverGT's Avatar
DONT EVER USE THE OEM JACK!!!! lol i have had bad experience with those darn things....like the car falling off it....when the wheels was offer the car...thankfully it landed on the bottom lca bolt and nothing else!!!!!
Old Nov 26, 2007 | 12:57 PM
techbod's Avatar
^^definitely use with extreme caution personally I hate them, as for answer #4 it does look confusing but there is quit a large area so you should still be able to put the axel stand in there but the other points on the first post would be a good location for the stands
Old Nov 26, 2007 | 03:28 PM
Retard Riot 686's Avatar
OEM Jack is complete garbage haha i hate flats cause i fear for my car when i use it
