Timing bel change - shop at NJ - where?
Old Apr 4, 2007 | 10:00 PM
vrso2's Avatar
Default Timing bel change - shop at NJ - where?
Hi, i need to change my timing belt on my a6, 2.8, V6. I got 92 000 miles on it. Do anybody know some good and also not expensive shop to replace the T belt? Thx for responds.
Old Apr 4, 2007 | 11:42 PM
SSn's Avatar
SSn
Default RE: Timing bel change - shop at NJ - where?
Do it yourself, it's easy. This is DIY friendlt forum we can help!
Old Apr 4, 2007 | 11:56 PM
vrso2's Avatar
hahahah good help
For me better pay 400$ then play all day with my audi at parking lot hahah
I found this kit: http://www.blauparts.com/proddetail....B&cat=1723
I need some one to install I already call to my friend. He may be able to do it by 300-400$. But he never did audi before So, i'm so scared
Old Apr 5, 2007 | 12:13 AM
SSn's Avatar
SSn
That's the kit I used.
It should not take all day =) If your friend done timing belts before he'll be do just fine. It's similar on all cars.
But, I suggest you buy stuff divided, unless you really want to change those seals. That will be 3 times more complicated rather then just replacing the belt and pump alone. You will need Crank blocking pin for sure, and something to hold the cam sprokets when tightening the bolts.
Without seals it's easy, almost impossible to do wrong. =)
Old Apr 5, 2007 | 10:35 AM
vrso2's Avatar
i dont need to change camshaft seals, i already did. I need to change just: Thermostat, water pump, belt and pulley.
Old Apr 5, 2007 | 04:46 PM
SSn's Avatar
SSn
Are we talking about the same seals? There are 4 of them for each side... Strange that your timing belt was not serviced at the same time.
Well, then you don't need to worry about anything. Your friend just got to take everything apart, mark the sprockets and count belt teeth between marks, then install new belt at the same position with the same teeth interval. Then Rotate engine by hand few times (spark plugs out) and check marks again. You can ignore all special tools manual says to get, except for the 32mm key or something to unscrew the cooling fan.
Rodneylynn1977
Jun 29, 2010 09:00 AM
ArcticZ
Mar 13, 2010 01:37 PM
fritz
Jul 23, 2007 06:11 PM
