Timing Belt
No problemo. I have a dry sense of humor that some people aren't too sure about. It gets me in trouble sometimes. Hopefully I will be safe on Audiforums. Just know I like to kid around and am enjoying getting to know the members here.
ORIGINAL: topj
yea but do you think they changed it already or not? cause i dont wwanna buy the kit if i dont gotta right?
All,
The below para. isstraight from the dealer; I've got 96K on my '03 2.7T A6...it's time to bite the bullet and get my timing belt done! Are there any parts the dealer may have left out that any of you know should be replaced along with it? He mentions the timing belt, tensioners, rollers, coolant, thermostat, ans water pump.
Hi Louis,
My name is Ray, and I’ll be responding to your questions pertaining to maintenance for you 03 A6 2.7T.
As for maintenance requirements, on the 03 models they run on every 1 year/10,000 mile intervals.
So to answer your question pertaining to a 75,000 mile maintenance interval, there is not one that applies, however depending on when the oil was
changed, you would go 1 year/10,000 miles between oil and filter changes.
Looking at the maintenance price for the 80,000 mile service for your 2.7T, it would be $909.95 + tax. Service would include oil and filter change,
tire rotation, spark plugs being replaced, air and pollen filter replacement, fuel injector flush, brake flush, fuel and engine additives, checked stored memory in the electronic control module, lubricate the sunroof, door latches, and the hood and trunk latches, road test vehicle.
As for the timing belt, that would be an additional charge of $969.00, and the price includes the timing belt, tensioner, rollers, coolant, thermostat, and
water pump.
On the road test we would test the clutch to insure that it is operating properly, if not, unfortunately, there is not any overlapping labor, so there would not be a cost savings to replace it at the same time that the service and the timing belt are replaced.
If you have any further questions, feel free to call me at 719-575-7865, or just return the e-mail.
Thanks for you inquiry,
Ray
This is straight from the dealer in Colorado Springs, hope it helps.
Louie
Hi Louis,
water pump.
Ray
Louie
I'm a believer in regular maintenance, but the work your dealer recommended for about $909 would cost about $400 at a good independent shop. I just had spark plugs and the gas filter replaced for about $200 and when he did the brake fluid a little while ago, it was about $150. Throw in a pollen filter for $25.
My TB parts cost $360 and the labor (same shop) was 6 hours at $75/hr. He recently jumped his rates to $78. I guess California is more expensive than the midwest.
I was about to perform Lasik surgery with a rusty fork... on myself, until I read the piece about your Unc being a mechanic!!!!
I just paid $1500.02 for Timing, Water Pump, Oil & OilFilter, Anti-Flush and a couple of Ting-a-Ma-Jigs... Oh, and he gave a loaner, and he is not a "Stealership!" I am in Northern Maryland, so everyting is "WTF!!!!" If I weren't a Sloth and confident in HR Motor Cars. I could have driven to PA or DE and saved .89 Cents.
That is my time... Thank you... God Bless...
