Timing Belt Change - DIY Cam locking tool
My method of locking the cams caused some discussion.
I would like to update this thread and say it's been more than a year since I changed this timing belt. Car has been driven pretty much every day by my 16 year old daughter who is not "light' on the throttle.
Still runs like a watch.
Engine still runs like a watch.
I do not normally post but when I happened to see this I couldn't resist. This is NOT an acceptable method of locking the CAMSHAFTS for timing belt replacement. You have the cam pulleys locked (sort of) not the camshafts. The cam pulley bolts need to be loosened and the cam pulleys "cracked" free from the cams. The pulleys need to spin freely. The pulleys lock to the camshafts by an interference taper fit so they can freewheel when you install a new belt and set tension. If you do it like you did, the timing belt will not tension correctly and the timing cannot be precisely set. PERIOD!!! If your cars still running, great. But is it running as great as it could be? I would say you dodged a bullet. One tooth off will cause tons of timing issues. For people looking into doing this job, please DO NOT use this approach. You are asking for a disaster.
It's been about 4 years since I changed the timing belt on that A6. It's about ready for a new one, still runs like a watch.
I have a degree in Mechanical Engineering from a top 10 University (lots of theory). I have spent 30 years building all manner of cool cars, my specialty is high performance motors (lots of practice). Theory and practice are different.
It's correct that the "proper" way to set the timing on these engines is to free wheel the cam sprockets. In theory it's better. One of the things I like about these German designs is their over the top fussiness. So many things are over thought and over designed. It's what I like most about these cars. They are a pleasure to work on.
In practice, I don't think the tiny difference matters much (do some math and think about it). So many of the motors I work on now have variable cam timing, it's easy to see the effect of relative timing on performance. When you are the dyno you can see how varying the cam timing changes the power. In the macro, having variable timing is terrific. In the micro, over the RPM range a degree or so, it's not so much. That's my opinion, yours can be different.
BTW, I did another one of these a couple of years ago (changed timing belt) and borrowed a cam locking tool just to see the difference. The difference between these methods was not perceptible to me. I marked where the sprockets were relative to the cams before and after setting the tension. They didn't move perceptibly. Theory and practice. YMMV.
The thing that gets me,is that the special tool is REALY not that expensive and well worth the investment...why roll the dice and gamble you want to do this ONCE and RIGHT! the first time till ..Now you have the tool! so when it's time to do it again...you have the tool...
These cars are like hand grenades with the pins pulled..just waiting to go BOOM!...there is NO margin for error...this gentlemen was just plain damn lucking the car started and is still running...I love ingenuity and sometimes you "have to" come up with a fix...Great but do these repairs the way the guys who DESIGNED them specify to!! You will save a lot of time, money, headaches and heartaches.....
Don't cheap out on "Basic Tools"..You'll pay dearly down the road!
Really not lucky. Two engineering degrees taught me to believe in physics, not tired tropes.
You are entitled to you opinion but if you understand how a system works, you don't need to rely on someone else's thinking.
I actually have an engineering degree also and was a US Air Force aircraft mechanic Everybody's got their right to do as they "D well please"..But I'm a big fan of of following known tech data/Tech orders esp if it is "NOT MY Equiptment"....so when and if something goes south you have covered your tail...those tools are well worth the investment..so don't give me that no-sense actuallyI'm surprised to here this from you sir!...You sty that whip is still running strong?? how many years later?? Miles?? Bout time to do it again...I think it is also a time change item too but I would have to check the specs.
When in doubt follow ALL technical data! PERIOD!
pagrosse
Apr 28, 2013 09:08 PM
