tiptronic auto shifting from 5-4
Old Jan 22, 2007 | 08:23 PM
fusnowtiger's Avatar
Default tiptronic auto shifting from 5-4
anyone else have an issue with your tiptronic transmission shifting from 5-4 then back again under moderate to heavy throttle?
Old Jan 22, 2007 | 11:25 PM
2k S4's Avatar
Default RE: tiptronic auto shifting from 5-4
It's your chip. The ECU has a hard time knowing what the loads are & it's hunting gears.
If you have Lemi, increase or decrease loads. If you increase, it will shift down & hold more, if you decrease it, 5th will hold.
Or you can either shift into 4th, or give it a little more gas slower. Shifting is also dependent on how fast you push down the pedal.
Old Jan 23, 2007 | 12:18 AM
you think a tip chip would solve that or would I have to go with a full valve body upgrade?
Old Jan 23, 2007 | 02:46 PM
2k S4's Avatar
ORIGINAL: fusnowtiger
I'm not sure but my car doesn't hunt gears at all. I'm very happy with it. It seams to hold gears more when you are on it.
In 5th I have to give it a lot of peddle to change gears. Mine only seams to **** when I want it to.
You can also VAG-Com the trans to hold 1st gear.
Old Jan 23, 2007 | 06:04 PM
craig_mack's Avatar
I noticed recently that my transmission will do the same.. when in TIP mode in 5th gear, if I accelerate hard it will auto shift down to 4th, then return to 5th when I let off. I never had this issue till recently, it bothers me....
Old Jan 23, 2007 | 06:18 PM
2k S4's Avatar
ORIGINAL: craig_mack
It's suppose to do that when you hit the kick down. Even in TIP mode.
If you press the pedal down about 90%ish, that is WOT, if you go past that it hits the "kick down" & will shift.
You can see where the switch is on the gas pedal, so just get used to staying on throttle with out hitting the kick down.
1998audiA6_Q
Mar 10, 2013 10:58 PM
avantgarde98
May 5, 2011 04:30 PM
emzaudi
B8 Models
May 28, 2009 10:12 PM
8cyls~of~love
Feb 7, 2008 12:51 AM
lnewman
Jan 22, 2008 05:27 PM
