TIPTRONIC NOT ENGAGING. HELP
Hi everyone I have an 2000 Audi A6 2.8L. I just drove it this morning only to find out that my tiptronic won't work and the auto transmission won't engage to the 5 gear. The LED display that indicates which gear the car is in, which normally indicates this by inverting the display of the selected drive, wouldn't show ANY gear as selected .
Hope you found the answer by now, but if not, here goes. Your tranny is operating in full hydraulic mode -- gears one through four mitout any electronic override -- because something electrical is broke. When my '99 did the same, diagnostics pulled a code that indicated a fried multi-function switch. I changed it myself to save $400 on labor, but it's no picnic.
I had a different problem in that the Tiptronic switch appears to have broken. When I tried to go the Tiptronic mode nothing happened. Normally I heard a plastic clicking sound which in hind sight probably wasn't good. The Tiptronic now doesn't work but the transmission still works OK. More of an annoyance than anything else. What does seem strange is that the shift points are now more aggressive. I'm OK with that and will probably investigate as an intellectual exercise. And I thought Jaguars were strange.
Not always the fix, but may apply to some of you.
DIY: Get your Tiptronic working again (W/ PICS) VW Passat/ Audi
