tiptronic steering wheel question
Old Jun 25, 2007 | 06:31 AM
V6A630v's Avatar
Default tiptronic steering wheel question
hi all , i have a 1999 2.8 v6 tiptronic and i was wondering if a 4.2 s6 tiptronic steering wheel with the tiptronic buttons will fit onto my car and work. i have no buttons on my wheel at the moment . will the wiring be behind the wheel to connect to??? not too good with electrics so need advice before i buy. Thanks very much
Old Jun 25, 2007 | 06:38 AM
techbod's Avatar
Default RE: tiptronic steering wheel question
only way to find out is check the wiring, lots of same brand cars use one loom so you tend to get lots of loose ends that are unused
Old Jun 25, 2007 | 06:50 AM
V6A630v's Avatar
hi dave thanks, will it harmmy air bag if i take it off to find out if i dont disconnect it. ? dont want do no damage!!
Old Jun 25, 2007 | 07:02 AM
techbod's Avatar
remove the ground wire from the battery this cuts out any chance the airbag will go off which I doubt any way ( check if you have the code for your audio ), once completed just hook the ground back up and this will reset the air bags
Old Jun 25, 2007 | 07:10 AM
techbod's Avatar
Removing and installing driver's airbag unit as of 08.97 Caution[/align] Heed safety precautions for working on airbags →Chapter. 1- Steering wheel q Removing →Chapter q Attach loose cables at locations marked by -arrowA-. 2- Plug for coil connector 3- Connector for airbag unit 4- Multi-point socket head bolt, 60 Nm q Always to be replaced 4- Hexagon bolt, 70 Nm q Always to be replaced 5- Airbag unit t Removing Caution[/align] Observe the safety precautions for working on airbags →Chapter. – Release steering column adjuster. – Pull steering wheel out and up as far as possible. – Move steering wheel to vertical position. – Slacken off first Torx bolt T30. – Turn steering wheel back by 1/2 a turn and slacken off second Torx bolt T30. – Unplug connector - →Item- from airbag unit. – Set down airbag unit with impact cushion facing upwards. t Installing – Make sure connectors are heard to fully engage. Caution[/align] Make sure there is no-one in the vehicle. – Switch on ignition and connect battery earth strap. Note![/align] t After connecting battery, remember to check vehicle equipment (radio, clock, electric window lifters) in line with Workshop Manual and/or owner's manual. t If airbag warning lamp (K75) indicates a fault following installation, use vehicle diagnostic, testing and information system -VAS 5051 A- to erase and re-interrogate fault memory. 6- Threaded bushing 7- Torx bolts (T 30) q 7 Nm 8- Torx wrench (T 30) 9- Coil connector with slip ring 10- Connector for heated steering wheel
[IMG]local://upfiles/12092/CFDF20D767B54430AF71B81CBABE0146.jpg[/IMG]
cekren
May 13, 2014 07:47 AM
Mixmastermike
Jul 2, 2008 08:21 PM
Big Blue S90
May 27, 2006 11:44 PM
rowingdude
May 17, 2006 05:23 PM
rowingdude
Nov 1, 2005 01:47 PM
