Torque specs? (timing belt)
Old Oct 14, 2008 | 06:44 PM
Leeer73's Avatar
Default Torque specs? (timing belt)
Alrigt guys, I'm almost done with my TB job, but I cant find the damn torque specs. Anyone point me in the right direction? Thanks!
Old Oct 14, 2008 | 08:44 PM
ryuuoh's Avatar
2.8? 3.0?
Old Oct 14, 2008 | 09:34 PM
Leeer73's Avatar
it's a 2.8. Well my torque wrench was f'in up so I had to tighten the water pump, tensioer and pulley by hand. I got it tight enough without over tightening it I hope!
Old Oct 14, 2008 | 10:03 PM
ryuuoh's Avatar
water pump is the touchy one, 7 ft/lb.
Old Oct 14, 2008 | 10:19 PM
Leeer73's Avatar
BTW, thanks Ryuuoh for all the help man!
I tighten it more than 7 ft/lb I'm sure. But all the bolt were prety evenly tightened. You think it will cause problems if the water pump is tighter?
Old Oct 14, 2008 | 10:22 PM
ryuuoh's Avatar
Hard to tell. If you got the bolts evenly torqued, it should be good. The issue people have had is breaking the bolts off.
Old Oct 15, 2008 | 05:50 AM
Leeer73's Avatar
Luckily I didnt run itno that problem! Thank again Ryuuoh!
CRuby
Dec 11, 2013 10:19 PM
distilled
Mar 29, 2011 09:28 PM
wgmasters
Sep 13, 2010 06:51 PM
Stunt101
Apr 5, 2010 05:54 PM
Andyrew
Apr 8, 2007 05:51 PM
