Transmission Fluid change on High mileage?
Old Apr 6, 2009 | 09:34 AM
  #41
vrso2's Avatar
Default hmm
well, so you guys looking just for AT maintenance.
I was thinking, you want to change whole AT fluid (about 9 quarts).
But, may be you right. New filter give you 80% improvement in shifting.
I got 128k on mine and i'm about do the same. My mechanic from Azerbaijan gona do it for 20-30 bucks.
BTW: Ja neznam
Old Apr 11, 2009 | 10:07 PM
  #42
jason23silver1's Avatar
Just so everyone knows my car is still running great. My opinion is to "Change your transmission fluid and filter". It will make your car shift smoother than ever. I might change it again in 5000 miles to be on the safe side. Everyone needs to realize that when you work on your own car the job will get done the right way. I take extra time to clean every part. I have spent hours detailing my engine, undercarriage, transmission. As long as you don't rush a job it will get done right.
Old Apr 11, 2009 | 11:14 PM
  #43
gmatov's Avatar
vrso2,
Ti znas. Cro je Croation. So one might trust one who is one's own in heredity. Both Jugoslavs. Both, also second gen, here, just we tend to trust our own more than, say, a "cake eater", keksar, and I don't know if that is spelt right.
vrso might be a combination of letters, and it might be your name.
If this means nothing to you, you probably are too Americanized. Forgotten or never knew your forebears tongue.
Dobro noc,
George
Old Apr 12, 2009 | 01:21 PM
  #44
jay6's Avatar
I would go with checking the fluid first before changing it. Your not currently having a problem and that may not be the case if you change it (that whole gamble thing). If your fluid isn't nasty and your shifting well, it may be best to leave it. There is a post in another part that references having a whine and overfilling the tranny to get rid of the whine and dealership changing again with no improvement. It might be best to leave it. Just my 2 cents
Ok, Now I've read the rest of the posts and the results following the change. I've now had a change of heart and I am thinking that I should change the fluid in my A6 too, just as a preventative measure. I must say that I know of a lot of older Audis with up to 300 k on the original trans fluid still going strong. I guess better lucky than good.
Last edited by jay6; Apr 12, 2009 at 01:49 PM. Reason: Didn't realize job was done.
Old Apr 14, 2009 | 02:06 AM
  #45
a6xlr8s's Avatar
changing the ATF on an Audi and changing it on a Tahoe are night and day. You need computer assist because you are bottom filling. It is not for someone to try if they have never worked on a sealed transmission before!
Old Oct 23, 2009 | 09:32 AM
  #46
whitey's Avatar
Default back from the dead
yep, digging up an old thread.
Jason/Chefro - how are the transmissions doing now? It's been over 6 months now.
need to change mine...not even going to get into how many miles are on mine
Old Oct 23, 2009 | 01:49 PM
  #47
NH_USA's Avatar
I thought this thread died an honerable death, but it looks like we can't let a sleeping thread die in peace. LOL
Old Oct 23, 2009 | 06:56 PM
  #48
chefro's Avatar
Whitey,
I'm happy to report that the tranny is doing great! - 4,193 miles later (daily driving).. I'm one of the guys that changed the ATF without temp monitoring, btw.
In the spring I'll change it one more time, although probably it won't make any difference.
I had and have though a tranny code all along (Consumption Signal - Short to Ground or Open Circuit - or smthing along those lines), but I'll get yo it in about 2 weeks time. I want to check the TCM connections.
Old Oct 24, 2009 | 09:18 AM
  #49
whitey's Avatar
lol. I did a search and came across this thread. I wanted to see how their cars have reacted after the fluid change. My car has a couple years of miles more than their cars and the trans is slipping on gear changes. I'm gonna try to change the fluid/filter and see how it does before I take it to a shop (hoping it doesn't require a rebuild).
Old Oct 29, 2009 | 07:47 PM
  #50
Smile
Well I am happy to report to everyone that my transmission seems great. I really believe that changing the fluid is a must!
