trunk button not working?
Old May 5, 2008 | 10:23 PM
johnstef's Avatar
Default trunk button not working?
Just got a 2003 A6. though i press the trunk button on the key fob and nothing happens?? What can be wrong?
Old May 6, 2008 | 02:00 AM
WeezyTT's Avatar
Default RE: trunk button not working?
mine doesnt work either. i dont think it worked on my last audi either, both 02 a6
Old May 6, 2008 | 04:53 AM
katcoota's Avatar
My trunk button used to work until the battery died. Subsequently when I reporgrammed it, I didn't do it quite correctly, so the trunk button stopped worked.
It's worth reprogramming the key fob to see if it fixes it. There is no need to go to the dealer for this (I think) but it depends on whether you have the imobilizer in the key fob or not. Mine didn't so it was not an issue.
Old May 6, 2008 | 09:38 AM
Truthteller's Avatar
I thought my trunk button was not working until today. I figured out instead of just pressing it I had to press and hold it. Try that and I think you should be ok
Old May 6, 2008 | 08:38 PM
johnstef's Avatar
i hold it down, and nothing? what can be the problem?
Old May 6, 2008 | 08:44 PM
afstud6900's Avatar
Banned
i have a 99 a6 and i just got a new keyfob and everything works but the trunk button on the keypad..on both of mine...but the guy at audi told me its not really suppose to cause of the handle on the trunk itsself and all you have to do is unlock the doors...but i dont know thats what i was told and im not worried about it.
Old May 6, 2008 | 09:47 PM
ppgoal's Avatar
My '03 is off the road and covered. But I vaguely remember all the button does is unlock the trunk. You still have to reach under and open it. Most American cars actually spring the trunk open when you "pop" it but not the German cars.
But I could be wrong, too.
Old May 7, 2008 | 10:02 PM
a6hcw's Avatar
Onmy 1996 A6 2.8L the wires to the push button in the glove compartment were broken, anda plastic leveron the trunk lock cylinder was broken. When I bought the car the truck would not open even with a key, so I workedthru the ski bag opening in the back seat to remove the latch keeper. The plasticlink leverand switchesfroma redesigned newer usedlock cylinder will fit onthe older lock cylinder, so there is onlyone key.The lock cylinders are actuated by a vacuum pump under the rear seat, so check the vacuum line from thepump to the trunk lock cylinder.Look for a broken vacuum hosenear the trunk hinge.
Thenight IpickedthisA6 up fromthe used car dealer, the sun roof popped open at a gas station when Ilocked the doors. So, another reason it doesn't work might be that the previous owners or their agents tampered with a few things.
Never buy any car with a bad engine, transmission, bent frame or other costly items.
The Bentley CD manual doesn't give much information on the truck lock cylinder with remote vacuum actuation. Bewareof missinformationabout not needing a shop manual, just because it doesn't cover everything.
Old May 14, 2008 | 12:41 AM
a6hcw's Avatar
On a 1996 A6 thetwo trunk switch wires at the glove compartment can fail behind the right hand rear glove compartment pivot and where they pass through a brass pivot pin with sharp internal edges. Also, these two insulated wires are too stiff for this application.Perhaps the plastic insulation hardened with age.The sharp internal edge may be removed from the brass pin with a sharpcountersink tool.
jp196400
May 12, 2011 03:13 PM
Tlag
Dec 19, 2008 09:48 PM
audi0104
Jan 21, 2008 10:15 PM
Robert D
May 15, 2007 07:31 PM
baal2005
Mar 16, 2006 01:18 PM
