trunk release button in door frame
Old Feb 19, 2007 | 11:32 AM
radiofrylock's Avatar
Default trunk release button in door frame
Hi All- New '03 2.7T owner in the DC area. My trunk lid switch was missing the button part (the plastic piece that you press), so I ordered a new one from worldimpex and now have the part. However, I'm not quite sure how to replace it. I could probably pop out the plastic piece from the new one and replace it on the old one, but I think it might be better to replace the whole switch if I can figure out how to get it out. Advice?
Old Feb 19, 2007 | 01:31 PM
marko_tomas13's Avatar
Default RE: trunk release button in door frame
What happened to me was that the button broke and came out, leaving a hole as you described.
I ordered a new switch (around 25$ CAD) and just replaced it myself.
The switch comes whole and you just toss out the old one. I pried the old frame and everything out gently with a screwdriver, removed the wire from the old switch, put it onto the new switch and then just popped the new assembly into the slot pushing with firm pressure.
Old Feb 19, 2007 | 01:48 PM
drneal's Avatar
No advice but I have a 2001 A6 and the button for the panic alarm popped out of the door pillar - dealer replaced it on CPO warranty.
Old Mar 3, 2007 | 08:45 PM
kaminar's Avatar
Basic instructions (from memory, so forgive me if I forgot about a screw or a bolt here and there):
1.Tools:
-flat head screwdriver (medium)
- small socket wrench (1/4")
- 11mm (i think) long socket
-needlenose pliers
2. Open both driver side doors. Use flat head screwdriver and hands to gentlyremovethe plastic floor trim by both doors.
- there are several clips on the bottom side that slide into that part of the trim; they squeeze into slits in the floor. Careful when popping out -- clips are metal, trim is plastic
- clips might remain inside metal floor -- use needlenose pliers to remove
2. loosen the B-pillar trim, but do not attempt to remove completely
3. from under B-pillar trim, push button and electric clip out from inside.
-use spare tools to keep space under B-pillar trim open
4. Remove top portion of button
- it's either brown or black
- 2 plastic edges on either side clip it in place -- need to loosen both
5. Replace with new button and fit inside trim
6. Replace trim as before
- note that floor trim is very flexible
- metal clips are moody and some like to slip
- get dirt out while the trim is off
- clean under seat
7. Test button and remote
Good luck!
-=K=-
Old Mar 3, 2007 | 09:25 PM
auditech79's Avatar
Audi only pays 10 minutes to replace the switch. You just pop it out with a poket scewdriver and pop in the new switch.
Old Feb 26, 2014 | 08:51 PM
Grams24's Avatar
Default Trunk release button
I need the botton for inside door jam, thank you
Old Sep 28, 2016 | 10:42 PM
rmsarma's Avatar
can soomeone please help with the oem part number or a url to purchase this switch
Old Sep 28, 2016 | 10:49 PM
rmsarma's Avatar
can you please share a url for the item or the oem part number for that switch am desperately looking for it
rmwebb1
Jul 13, 2011 10:50 AM
Bastid
Jul 3, 2010 05:48 PM
Bastid
Jul 3, 2010 05:24 PM
gofaster
Dec 14, 2008 08:31 AM
racer187
Mar 16, 2008 09:28 AM
