Turn Signal not blinking
Old Sep 17, 2012 | 01:54 PM
LBoogie's Avatar
Default Turn Signal not blinking
Good Afternoon,
I have an 2004, A6, 2.7, all wheel drive audi. My turn signal is not blinking just stays on. I looked at the fuse box and there was nothing in there for turn signals. What would this require?
Old Sep 17, 2012 | 02:07 PM
nm3210's Avatar
Usually means you need to replace the hazard switch (the red triangle in the middle of your dash) because that is where the blinking signal comes from.
Old Sep 17, 2012 | 09:30 PM
budhani786's Avatar
OR
the blinkers are low on blinker fluid
Blinker Fluid - $18.95 : KaleCoAuto.com, Your home for the rare, unusual, and hard to find auto parts.
that there is "audi approved synthetic"
Old Sep 17, 2012 | 09:39 PM
z28pete's Avatar
Have you checked that all the bulbs are working, if a bulb is burned out that side blinker is just going to stay on without blinking.
Old Sep 18, 2012 | 12:53 PM
nm3210's Avatar
Wouldn't it normally flash really fast then?
Old Sep 18, 2012 | 06:13 PM
hxgaser's Avatar
Originally Posted by budhani786
OR
That's PFM!
Old Sep 18, 2012 | 06:14 PM
hxgaser's Avatar
BTW, Ditto on the hazard switch.
Old Aug 5, 2017 | 01:53 PM
Arthur P Putrasevix's Avatar
Default A6 2003 saloon
Hi there
Any one have a answer for why my indicators not bling stay steady,I checked the fuses,check the relays but not shure which is the right to replace,there is more than one location for relays one is on front under bonett second straight under drivers panel where the fuses located.any replay will be apriciatted
vtraudt
Feb 25, 2014 02:27 AM
neekilo
Sep 11, 2013 10:35 PM
1998audiA6_Q
Jan 8, 2011 03:03 PM
71custom
Feb 9, 2009 03:49 PM
sdaudi
May 23, 2006 11:52 PM
