uneven tyre wear
Old Jan 26, 2008 | 05:40 PM
krishcanag's Avatar
Default uneven tyre wear
Hello
Well actually, the tyre wear is hardly noticable, but can see that front tyres, about 10000 on it now, show a little more wear on the outside than inside, both, but driver side is clearly noticable.
Steering is ok, no wobbling, but if hands off, or sometimes when repeated breaking (no hands) the steering wheel would trun a little anticlockwise. I get the feeling that I have just apply a little, little force to keep steering wheel stright and stop it drifting anticlockwise.
Does anyone think this might be a tracking issue or a 4 wheel alignment job? Or nothing
krishan
Old Jan 26, 2008 | 05:53 PM
formulagigi's Avatar
Default RE: uneven tyre wear
get an alignment.
stock suspension?
Old Jan 26, 2008 | 05:54 PM
WolfsA62.8Q's Avatar
Alignment can and will affect tire wear. Audis are known to be hard on tires, check the control arms/bushings.
Old Jan 26, 2008 | 08:03 PM
auditech79's Avatar
Definately a wheel alignement issue.
If the outer area of the tire is wearing its most likely a toe issue. To adjust the toe you need to adjust camber first so a 4 wheel alignment is needed.
Worn upper control arm bushings won't affect tire wear enough to notice, none the less they should be checked.
Old Jan 27, 2008 | 02:13 AM
joetm's Avatar
If you said the wheel is turning when you are braking then your brakes may be pulling and that should be fixed ...
Old Jan 27, 2008 | 07:02 AM
krishcanag's Avatar
even though it is also noticable when braking, its not all the time, but the general drift is very slightly there, so I would agree a 4 wheel alignment will have to done, which is costly!!! eeeeeeehhhhhhhhh
more for the tax man!!!
krishan
Old Jan 27, 2008 | 10:47 AM
euro_2nr's Avatar
I had this not too long ago. I went to a VW dealer since it was cheaper $100
Old Jan 27, 2008 | 11:23 AM
I paid $100 for my 4 wheel alignment at PAS, a local Indy shop specialized in German cars as well as Ferrari and Lotus. They have that new machine, supposedly the best from Germany... Beizbarth or something like that
tom225
Mar 15, 2013 03:10 PM
mtboulder
May 3, 2009 11:28 PM
C_TAYLOR
May 6, 2008 11:32 PM
Palindari™
Jun 5, 2007 03:45 PM
duburban
Dec 10, 2006 05:11 PM
