Unknown Alert Symbol
Old Jan 8, 2012 | 11:11 AM
TomKat's Avatar
Default Unknown Alert Symbol
2003 A6 w/ 2.7L Turbo.
Recently observed a symbol in the dash that looks like a circle surrounded by another segmented circle.
I am thinking it is a brake pad wear alert however I don't find that symbol in the Owners manual or Bentley's.
Anyone know what it is?
Thank you
Old Jan 8, 2012 | 12:04 PM
budhani786's Avatar
Thank you
that description sounds like the brake pads to me. i believe it is in the manual. atleast it is in my 01 manual.
if it looks like this its the brake pads: (O)
Old Jan 8, 2012 | 01:00 PM
TomKat's Avatar
Yeah, it looks something like that, the ( ) are broken up into three sections each.
I agree, it must be the front pads...
Thanks
Old Jan 8, 2012 | 01:33 PM
OGBULLYLOCDAWG's Avatar
you should post a photo up of some sort;
Until then;
Old Jan 9, 2012 | 07:44 PM
TomKat's Avatar
Yep, That's it "Brake Pads Worn"
Thanks OGBULLYLOCDAWG
Pads and Rotors are on order: Akebono pads and Centric Drilled and slotted rotors
Thanks again
Old Jan 15, 2012 | 01:07 AM
CRuby's Avatar
TomKat, Did you check to see if you have 2 pads per rotor or 4? These models have 2 possibilities for brake setups & rotor sizes.
Old Jan 15, 2012 | 08:51 PM
TomKat's Avatar
CRuby,
Yes I checked, it is a two pad /caliper setup.
Turns out there are two different rotor diameters as well 312 and 321.
I got the parts at Rock Auto and installed the pads and rotors Saturday
Old Jan 15, 2012 | 11:39 PM
bargarbutt's Avatar
Default scaring the children
Clowns may be doing their thing for religion, but are they scaring the children?
Old Feb 4, 2012 | 11:41 PM
heisse_mkII's Avatar
Are the front pads the only ones with the sensors? And how do you tell what type and size pads and rotors I have on the car?
Old Feb 5, 2012 | 10:26 AM
TomKat's Avatar
Default Fronts only
The sensors are only on the Fronts.
You can tell The type of pads required by looking at the Calipers
The link below will help with both the Rotor Diameter and Pad Type
Audi Brake Rotor Options - How To Measure Audi Brake Rotor Size
BTW- If you do the rears you will need a special tool that pushes the pistons in while twisting them. The tool is usually free from places like AutoZone regardless of whether you buy the pads there or not.
Good Luck
