Vacuum Leak? codes p0306, p0421, p1177
Old Aug 6, 2013 | 10:41 PM
nismo350z_burak_tx's Avatar
Default Vacuum Leak? codes p0306, p0421, p1177
Hi, I have a 2000 Audi A6 2.7T 6spd. The issue I'm having is on and after my 2nd gear, when i floor the gas after 2000 rpms the car jerks a lot. I took it to Autozone and they gave me these troubleshoot codes on my check engine light. I changed my spark plugs 3 months ago and this recently started happening. Is it a vacuum leak? are my turbos going bad since the problem happens after 2000rpm? bad DV? or is it a cause of a bad cat converter causing cylinder 6 to misfire?
Old Aug 7, 2013 | 09:54 AM
twopedalwarrior's Avatar
Sucks about the codes. Now, I am not going to totally break your *****, but did you google those codes?
I just did and it came up with a good amount of information of why your car is misbehaving...
02AudiA63L_65
Nov 11, 2013 07:30 PM
nismo350z_burak_tx
Aug 6, 2013 10:08 PM
HuskyRips
Aug 13, 2010 06:01 PM
HuskyRips
Aug 9, 2010 10:25 AM
gabeguimaraes
Feb 28, 2009 10:37 AM
