vag cable
Old Dec 5, 2008 | 10:45 PM
afstud6900's Avatar
Banned
Default vag cable
ok so i finally ordered a vag-com cable and im wondering where to get the software for this, and how to use it,, ive never dont it before.. but one thing i want to do is the window remote mod where you hold the unlock/lock buttons and the windows go up and down ect. also, what else can be done with the software and cable?
Old Dec 5, 2008 | 11:02 PM
CosminTX's Avatar
that`s a easy question, usb cable if is not original needs an usb drivers to be install , after that u have to set from laptop the usb port and the right com , once u done this the vag com will comunicate, and found the interface. software u get it free online with limited use, and pay for license for full version and all the benefits...
with free version u may change the transmision code, engine code, central lock code where u lock /unlock with one button , open/close windows with remote , automatic lock after 10miles/h speed, beep/no beep set alarm , also u can read and clean fault codes and engine lights , probably u may recode other modules but not sure..is limited
Old Dec 6, 2008 | 01:17 PM
nm3210's Avatar
software: http://dl.getdropbox.com/u/57832/Audi/Release4091us.exe
Door lock thing (including window): http://www.vaglinks.com/Docs/Audi/C5...LockCoding.pdf
Another typical thing to do with the software is to change the engine and tranny coding. Typically the a6's engine coding ends in a 2 and a lot of people have been changing it to a 1 (which some claim is what the A4 is set to - see here and more specifically here).
And depending on your tranny you can make it so the tip doesn't automatically shift into 2nd, and change it into the so called "sport mode". On mine (99 a6q), i only can change from regular mode "00000" to this so called sport mode "00010" - newer trannys can use other numbers (again, see the link up there).
shuggy81
Jun 19, 2013 12:38 PM
POWERTRIP
Sep 28, 2012 01:40 PM
HulkB5
Aug 3, 2010 11:34 PM
1.8TK3MP
Feb 21, 2008 09:50 PM
Semper VW
Jan 9, 2008 10:06 PM
