vibration at redlight???
Old Sep 28, 2007 | 08:58 AM
tahoehtp's Avatar
Default vibration at redlight???
just tryin to track this one issue.
while I'm at stop light, brake on. I feel small vibration. it stops after I depress the brake and go.
it's only happening while I'm in D and brake pressed, won't happen anyother time.
it gets little annoyed when I have a/c on it's bit more.
and I've search through etc.
maybe motor munts? or I read this about breather hose.
http://www.audiworld.com/tech/eng79.shtml
and doesn't look like torque converter
detail of the car is
99 A6 2.8L
93k on odometer
just picked it up week ago
Old Sep 28, 2007 | 10:29 AM
tahoehtp's Avatar
Default RE: vibration at redlight???
btw forgot to mention, this is happening before seafoam... so it's not seafoam related.
Old Oct 2, 2007 | 03:02 PM
Poor Person's Avatar
I'm no mechanic, but it sounds light mis-firingplugs. I got this statement from a "Astro-Snot", by the name of JRL. Get the code reader and save yourself sometime.
I replaced the plugs in my "Ole tmr", from Bousch to Denso and the next day I was driving out of the PL, and I noticed that my idle was alittle rough. I am just trying to get on the Beltway, and break north!
But my car sounded rough and was riding like it wanted to call "Earrrrrrrl". Any way got Thee Pit Guy to check the codes, and I had fried to Ignition Coils 1&3, replaced them and about a week later 2,4&5 went.
Forgot to mention that when I would put on the brakes behind someone in traffic, the car acted like it wanted to run up in someone. Good luck.
That is my time... Thank you... God bless...
Old Oct 2, 2007 | 03:08 PM
techbod's Avatar
Default RE: vibration at red light???
exhaust heat shield
Old Oct 2, 2007 | 04:08 PM
tahoehtp's Avatar
ORIGINAL: avant80@2.6
exhaust heat shield
hmm is that make the car vibrate well not a lot but feel is on steering and seats?
I haven't seen any error codes on the obdII either.
Old Oct 3, 2007 | 07:21 AM
techbod's Avatar
if its that type of vibration and only happens at idle then it has to be and engine/transmission mount and since there is no fault codes it makes it harder to diagnose ( you might want to check all the belts to see if anything is wobbling like a pulley )
Old Oct 3, 2007 | 10:12 AM
tahoehtp's Avatar
avant80@2.6 that's what I'm suspecting though it won't do it on when it's in park.
I'm gonna check the play in pully belts etc. and see.
thanks
Old Oct 5, 2007 | 02:10 PM
0 0 0's Avatar
My car does this as well... i also have a 99 A6 2.8 quattro
Old Oct 5, 2007 | 11:25 PM
jcyj2's Avatar
mine too
rarely has stable idle. probablyonce out of 100 stops is quite good.
Old Nov 1, 2007 | 02:46 PM
saboa6's Avatar
Had same problem, it was ignition coils.
Bluv
Oct 5, 2009 05:43 PM
Boostmore
Aug 25, 2009 11:03 AM
aabbyen
Oct 15, 2006 07:39 AM
Ziggy2609
Mar 16, 2006 01:56 PM
Ziggy2609
Mar 15, 2006 10:53 PM
