warm up catalyst code
Old Jul 14, 2010 | 05:02 PM
Turbo123's Avatar
Default warm up catalyst code
The code p0421 (warm up catalyst) came up on my 2001 A6. What exactly does this code mean? I deleted the code and so far it has not come back on the same day after driving it.
Old Jul 14, 2010 | 11:15 PM
A6Driver10's Avatar
It may be a sign of CAT converters going bad, or Post CAT O2 sensors going bad. Try to replace Post CAT O2 sensors first. It worked on my car. You can also try a trick with a diode to save money on new sensors. The trick works fine. I tested it. Unless there's something else going on with sensors, you should not see these codes anymore.
Old Jul 15, 2010 | 11:00 AM
Turbo123's Avatar
Thanks a lot if the code comes up again I will try replacing the sensors first.
Euge82
Sep 16, 2014 10:10 AM
Spotty
Mar 25, 2014 09:53 PM
mogwai88
Mar 31, 2012 12:09 PM
hankeester
Feb 17, 2008 03:52 PM
carhopper
Jan 13, 2008 07:16 PM
