Water in the right back seat
Old Mar 22, 2012 | 11:01 PM
sukisuru's Avatar
Default Water in the right back seat
There is water on the floor of the right back seat coming from the vents under the passenger seat. Any ideas what the problem is and how to fix it.
Thank you
Old Mar 23, 2012 | 02:05 AM
bigdadi's Avatar
Check the area under the battery if water sitting there. There are 2 drain holes, likely blocked and water sipping into venting from air filter housing when cornering - overflown.
Check if the air filter housing has any gap or crack, you can use silicon chaulking to repair and clear the 2 drain holes.
Also possible sunroof drain problems
https://www.audiforums.com/forum/s-c...r-side-172882/
Old Mar 23, 2012 | 07:52 AM
M5S5's Avatar
Tech Certified
Better pull the carpet up in the front , it is probably wet also.
The problem is audi likes to put modules under there in black boxes.
Pull them out & make sure there is no water in them. If there is dry them out ASAP!
Old Mar 23, 2012 | 10:23 AM
sukisuru's Avatar
Water only comes when a/c is on, also air filter housing is higher then the actual battery
Old Mar 24, 2012 | 02:52 PM
bigdadi's Avatar
Maybe evaporator pan drain hole/hose blocked ... water overflown from pan.
Old Mar 24, 2012 | 07:27 PM
M5S5's Avatar
Tech Certified
Soooo , did you check for water under the front carpet?
If you have water in the back you will also have it in the front where modules can reside. Especially if you have a clogged evap drain.
It is very important to check this or you will have expensive problems down the road.
Old Mar 25, 2012 | 03:15 PM
sukisuru's Avatar
Where is the evaporator pan drain?
Thank you
Old Mar 25, 2012 | 04:34 PM
M5S5's Avatar
Tech Certified
Under vehicle , usually some were around the transmission tunnel. Blow out with a little compressed air & stand back or you will get wet!
Old Mar 26, 2012 | 01:49 PM
altonachrome's Avatar
Definitely heed M5S5' wise suggestion...if you have water in the right back it's highly likely you have water throughout vehicle. You should pull ALL carpet because the chassis channels allow water to flow freely from back to front and vise-versa. Would also pull up your back seat as you will probaly find water pooled up there as well. I, along with many, many Audi owners have had the water intrusion issue, if you have a sunroof the rear drains are probably clogged as well.
Old Mar 26, 2012 | 03:09 PM
M5S5's Avatar
Tech Certified
The carpet is wet from denial. Not to be confused with the river da Nile!
