What Diverter Valves To Use?
Old May 16, 2005 | 12:10 PM
Airf22's Avatar
Default What Diverter Valves To Use?
Hey,
For a 2001 a6 2.7t will a forge race dv fit or do i need the forge 007 "a line". Which one is the better one? Or which brands do you guys recomend that will fit easily, and give the best results with the best sound not using bov?
Old May 16, 2005 | 08:58 PM
Frost GST's Avatar
Default RE: What Diverter Valves To Use?
Yes, the race diverter will work. The 007 is a piston design where the race valve is a diaphram like the stock valves. You can customize the spring rates on the race valve to adjust the responsiveness. As far as which one is better that is all opinion, both are much better than stock valves.
Andy
Old May 16, 2005 | 10:51 PM
audi_first's Avatar
If you don't drive too hard and want to save some money, take a look at the 710N diverter valves from Audi TT
They are like $35 a piece.
Old May 17, 2005 | 02:14 AM
Airf22's Avatar
I do intend on pushing it sometimes and would like the better performance ones, also if one makes a nicer sound?
Old May 17, 2005 | 02:15 AM
Airf22's Avatar
oh i forgot to say i have the APR chip so it has more boost
Old May 17, 2005 | 04:36 AM
audi_first's Avatar
ORIGINAL: Airf22
in that case, go with forge
Old May 20, 2005 | 02:54 AM
Airf22's Avatar
Question still stands, which one is better for sound and performance?
Old May 20, 2005 | 03:09 AM
rs's Avatar
rs
far as i know, there isnt one better in preformance. couldnt tell you sound, ill let someone with more knowledge tell you that
Old May 20, 2005 | 01:27 PM
Frost GST's Avatar
If you are going to recirculate the valve and keep the stock air box system then there will be no or very little change in sound from any valve other than a BOV which dumps the air to the atmosphere instead of recirculating it. Of course this set up will cause a rich condition between shifts and could cause stumbling problems.
When changing to an aftermarket DV there will be a very small increase in performance of the car due to the new valves ability to hold higher boost pressures and its better responsivness. But the difference in performance between one aftermarket valve and another is too small to measure.
Andy
Old May 25, 2005 | 12:40 PM
Lyrad576's Avatar
Where would one find the Forge race DVs at? I am looking to chip soon and would like a fair priced DV to upgrade to.
Thanks!
