What the f now?!!
Old Feb 11, 2008 | 07:40 AM
  #21
bob martin's Avatar
Default RE: What the f now?!!
Sounds like a sticking valve. Might be a broken valve spring. Have you done a compression check?
Bob
Old Feb 11, 2008 | 08:39 AM
  #22
audijunky_1's Avatar
Nope, haven't done a compression check. would a sticking valve cause codes p0300 and p0304. wouldn't that just throw a code on the cylinder that is sticking??
Old Feb 11, 2008 | 11:09 AM
  #23
hxgaser's Avatar
Did you check your catalytic converter? Now I really think it is exhaust back pressure related.
Old Feb 11, 2008 | 01:01 PM
  #24
How do I check the catalytic converter???
All bentley talks about for my codes is fuel and ignition? Is there an area in the manual for checking the CAT?
Old Feb 11, 2008 | 01:41 PM
  #25
hxgaser's Avatar
Post #6
Old Feb 11, 2008 | 02:02 PM
  #26
I have done everything in post 6 except the vacuum gauge. where is that supposed to connect? I haven't tried the 02 sensor removal yet either. that will be next. I think the indie shop was just trying to rob me originally cause after I went to them the dealer said the CATS were fine. And everything was good for awhile. Guess I'll try the 02 sensor thing next.
thanks fellas
Old Feb 12, 2008 | 11:10 AM
  #27
hxgaser's Avatar
To be honest with you, I guess I never even looked at any vacuum lines on my A6. My previous cars had little screws on intake manifold than unscrewed to hook a vacuum gauge. I guess you can tap into any vacuum lines as well. Anyways, let me go look and see if I can find a location to tap in. Also I would imagine it is shown in Bently under vacuum lines.
Old Feb 16, 2008 | 01:03 AM
  #28
georave's Avatar
Hey guys i seem to have the same problem, after replacing thermostat, timing belt and water pump on my 2000 a6 2.7t the check ingine light came on a couple days later and my idle was weird right off the bat, i took the car back to the mechanic and i could not find anything but he felt the diffrence too, he checked the car's computer and it came back with bank 1 cat problem, he said that it needs to be replace but i just don't think that's the problem. any clues. BTW my car has 92000 miles
